Maintenance Munual for 3300 , solid valve lifters
rick.tedford(at)sympatico
PostPosted: Fri Mar 16, 2007 6:32 am    Post subject: Maintenance Munual for 3300 , solid valve lifters Reply with quote
Hello Listers : I compared Pete K.'s on line manual with the one on the Jabiru site , for the above noted engine . The Aussie version has 116 pages compared to Pete's 108 . I believe there has been changes to the maintenance schedule as the manual shows revision # 2 dated Oct. 30/06
mhcrowder
PostPosted: Fri Mar 16, 2007 6:43 am    Post subject: Re: Maintenance Munual for 3300 , solid valve lifters Reply with quote
Rick,
If you look at Suncoast Sportplanes website, http://www.suncoastjabiru.com/downloads.htm. They have both versions. The first one is for Jabiru 3300 up through serial number 33A 960 and the second one is for serial numbers above 33A 961.
Michael Crowder
info(at)usjabiru.com
PostPosted: Fri Mar 16, 2007 7:31 am    Post subject: Maintenance Munual for 3300 , solid valve lifters Reply with quote
Rick,
The manual on line at www.usjabiru.com does contain 115 pages and is the latest issue from Jabiru Aircraft, PTY.
Pete Krotje
Jabiru USA Sport Aircraft, LLC
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of rick tedford
Sent: Friday, March 16, 2007 9:31 AM
To: jabiruengine-list(at)matronics.com
Subject: JabiruEngine-List: Maintenance Munual for 3300 , solid valve lifters
Hello Listers : I compared Pete K.'s on line manual with the one on the Jabiru site , for the above noted engine . The Aussie version has 116 pages compared to Pete's 108 . I believe there has been changes to the maintenance schedule as the manual shows revision # 2 dated Oct. 30/06 .
I have not gone through the manuals line by line , however I would be cautious .
FYI
Best regards
Rick Tedford
PostPosted: Fri Mar 16, 2007 9:08 am    Post subject: Maintenance Munual for 3300 , solid valve lifters Reply with quote
Thanks Pete : I stand corrected . Hope all is going well
Cheers
Rick T
marin
PostPosted: Fri Mar 16, 2007 9:27 am    Post subject: Maintenance Munual for 3300 , solid valve lifters Reply with quote
The maintenance manual for the solid lifter engine has 103 the maintenance manual listed for the Hydraulic lifters is really the solid lifters manual and has 115 pages
Marin Streeter
Marin
