Tim Olson
Posted: Sat Mar 24, 2007 7:01 am Post subject: Good Test of cockpit lighting/Defrost Fans with Night IFR De |
For those who've been following the defrost fan thread, I've got
a good pirep of how my 60mm fans worked in actual necessary conditions.
Last night I had a great opportunity to test out my fans, and my
new cockpit lighting, with a late-night full IFR departure with
1/4mile vis in drizzle and fog and haze. I just recently reworked
my cockpit lighting with stuff I got from Stein, and it couldn't have
been better timing. Everything worked perfectly and made a big
difference in how easy everything was.
Also, the departure was very near a big wind-turbine farm, and with
the synthetic vision on the EFIS this made for a very interesting
but safe departure. I wish I had pictures to show on this one.
I did a combined write-up showing my lighting installation, along
with a good trip write-up that you may find enjoyable if you're
into those types of things. It was a great way to kick off the
fun IFR spring season here in Wisconsin.
Here's a link to both the story and the lighting install photos:
http://www.myrv10.com/N104CD/upgrades/20070321/
Jim Berry
Posted: Sat Mar 24, 2007 9:58 am Post subject: Re: Good Test of cockpit lighting/Defrost Fans with Night IF |
Great info on your cockpit lighting and good timing as I am making those decisions now for my panel. I recently posed the question of red versus blue lighting to a friend who is an ophthalmologist, long time pilot with 6 planes ( C421, C185 on floats, C150, Pitts, Fuqua jet, Eclipse vlj on order. Must be tough staying current in all his toys.) Without getting into a discussion of photoreceptors and how the eye works, his response is "if you are primarily interested in seeing outside the cockpit go with red lights. If you are more concerned about reading maps, charts, etc in the cockpit go with blue lighting." He uses only blue.
Jim Berry
40482 Finishing
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Mar 27, 2007 8:26 pm Post subject: Good Test of cockpit lighting/Defrost Fans with Night IFR De |
Here is an article on Flight Deck Lighting with some background on who uses
what.
http://208.37.5.10/hf/hf_sept-oct03.pdf
Kevin
40494
tail/empennage
Jim Berry
40482 Finishing
_________________ Kevin
40494
do not archive |
