Left Elevator - rivets don't fit
andrew.phillips(at)sympat
PostPosted: Thu Mar 29, 2007 3:57 am    Post subject: Left Elevator - rivets don't fit Reply with quote
dill them to 7/64"
Bruce Swayze wrote:
Hi Everybody,
I'm working on the left elevator for my RV-7A, and I ran into a
frustrating problem with some of the blind rivets required. There are
4 blind rivets on the top and 4 on the bottom of the skin, that hold
the skin to the outboard end of the E-606PP Trim Spar. This is the aft
spar on the elevator that carries the trim tab, and these are the
rivets forward and to the left of the little tabs that you bend over
on the skin surfaces. The rivets called for are MK-319-BS blind
rivets. They have brass-colored shafts. I tried every one of the
rivets included with my empennage kit, and none of them will fit in a
#40 dimpled hole. I tried a #30 hole in a piece of scrap, and it's way
too big. Nothing about this is mentioned on the drawings or in the
plans. All the other holes in this part are #40, and the standard
AN326AD3-3.5 rivets fit just fine. Am I missing something? Did I get a
bum batch of pop rivets? Or do I drill out the holes a little bit
bigger? If so, what size? I'm wondering if anyone else ran into this.
Thanks.
Bruce Swayze
RV-7A Empennage
sshook(at)cox.net
PostPosted: Thu Mar 29, 2007 9:42 am    Post subject: Left Elevator - rivets don't fit Reply with quote
Like Andrew said...7/64"
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
dhall(at)donka.net
PostPosted: Sat Mar 31, 2007 5:06 am    Post subject: Left Elevator - rivets don't fit Reply with quote
Also, go online and find a drill bit set that has all the wire gauge size
(#XX) drill bits from at least 1 to 60.
Add that to your shop tool collection. It will come in handy over and over
to be able to find the exact size bit you need for a given task.
Don Hall
N517DG (registered)
rv7 fuselage
http://rv7.donka.net
gmvouga(at)hotmail.com
PostPosted: Sat Mar 31, 2007 6:38 am    Post subject: Left Elevator - rivets don't fit Reply with quote
Yes! The super drill bit set is one of the most used tools in my shop.
Harbor Freight has a cheap titanium set that is on sale more often than not
for less than $20. The bits are okay, but I replaced al the common bits
(#40, #30, #12, #19) as they dulled with better quality. I always have the
bit size that I need.
Greg
[quote]From: "Don Hall" <dhall(at)donka.net>
Reply-To: rv7-list(at)matronics.com
To: <rv7-list(at)matronics.com>
Subject: RE: Left Elevator - rivets don't fit
Date: Sat, 31 Mar 2007 08:05:39 -0500
Don Hall
N517DG (registered)
rv7 fuselage
