helicat76(at)shaw.ca Guest
Posted: Fri Apr 06, 2007 10:38 pm Post subject: canopy gas shock |
I have recently purchased a Glasair I and I have been trying to find a replacement for my canopy gas strut. Does anyone have any information about where a person can obtain one, or where I would get the specifications, so that I can try to get one built? I have emailed the Glasair people twice, and have had no reply, so I am assuming that they do not sell them. Any help would be appreciated. I am in Canada.
Thanks;
Shona
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
rlhrlh(at)adelphia.net Guest
Posted: Sat Apr 07, 2007 4:52 am Post subject: canopy gas shock |
Hello Helicat,
I own a Glasair III, and have replaced the gas spring several times. If
you can verify that the two canopies use the same gas spring, I will
send on the part number and ordering info.
Good Luck,
Robert L. Hunter
N957DJ
Thanks;
Shona
lists(at)stevet.net Guest
Posted: Sat Apr 07, 2007 5:14 am Post subject: canopy gas shock |
Don't assume that the gas springs are the same for the GIII and the GI. I can't believe that Glasair Aviation has not responded. They are usually very responsive. Did you try the address, parts(at)glasairaviation.com (parts(at)glasairaviation.com)? Or call their main number and ask for the Parts Dept. They usually don't answer the phone, but if you leave a message they will get back to you.
Best Regards,
Steve
____________________________________________________________________
On Apr 6, 2007, at 11:37 PM, Helicat wrote:
Thanks;
Shona
Craymondw(at)aol.com Guest
Posted: Sat Apr 07, 2007 5:55 am Post subject: canopy gas shock |
The gas shock can be found at marinas and is used on boat hatches. If you buy it from a marine supplier don't say it is for an aircraft. The reason why Glasair doesn't sell them is because once the manufacturer found they where used on A/C, they shut them off.
See what's free at AOL.com.
robin02(at)mindspring.com Guest
Posted: Sat Apr 07, 2007 6:52 am Post subject: canopy gas shock |
Shona, the original kits were produced in the early 80’s and used a gas cylinder from Boeing. They were used on the overhead compartment doors of a discontinued plane. I have had several go bad. Measure the length of the closed cylinder when the canopy is closed and again the length when it is open. Auto parts stores sell these for rear hatch’s of small cars. They will likely not have what you need in stock but will have a chart that will list the specs you need and will special order it. The last time I bought them, I got the company name off the display and bought online. The minimum order required me to purchase three gas cylinders. Robin Young 286YM
Thanks;
Shona
[quote] [b]
Bruce(at)glasair.org Guest
s_korney(at)hotmail.com Guest
Posted: Sat Apr 07, 2007 9:28 am Post subject: canopy gas shock |
Shona...
Send me your canopy gas shocks and I'll recharge them for you... What
pressure would you like...
Best... Steve
----Original Message Follows----
Reply-To: glasair-list(at)matronics.com
Subject: canopy gas shock
Date: Fri, 06 Apr 2007 23:37:49 -0700
Thanks;
Shona
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/?icid=hmtag3
Posted: Sat Apr 07, 2007 12:29 pm Post subject: canopy gas shock |
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Bruce Gray
Sent: Saturday, April 07, 2007 12:52 PM
Subject: RE: canopy gas shock
Also www.easylift.com . RObin
Try http://www.guden.com/dampers.asp.
Bruce
www.glasair.org
Thanks;
Shona [b]
royschechter(at)yahoo.com Guest
Posted: Sat Apr 07, 2007 3:49 pm Post subject: canopy gas shock |
YOUR BEST BET IS A MARINE SUPPLY OUTLET. MANUFACTURED BY ATTWOOD. LISTED IN WEST MARINE CATALOG AS SPRINGLIFT GAS LIFT SUPPORTS. GET THE 40# RATING. COST ABOUT 23$.GOOD LUCK. ROY
NYTerminat(at)aol.com Guest
Posted: Sat Apr 07, 2007 8:22 pm Post subject: canopy gas shock |
Shona, you can get gas struts from McMaster-Carr. _WWW.MCMASTER.COM_
(http://www.MCMASTER.COM) , loook under gas springs.
Bob Spudis
In a message dated 4/7/2007 10:53:29 A.M. Eastern Daylight Time,
robin02(at)mindspring.com writes:
Thanks;
Shona
(http://www.matronics.com/Navigator?Glasair-List)
************************************** See what's free at http://www.aol.com
Posted: Sun Apr 08, 2007 5:31 pm Post subject: canopy gas shock |
Thanks for all the great suggestions, I will start looking into these options!
Shona
Posted: Sun Apr 08, 2007 5:36 pm Post subject: canopy gas shock |
Thanks Steve, but there in lies the problem, I am not sure what the best
pressure would be. My most unscientific experiment with the bathroom scale
suggests somewhere around 35-40lbs, but that could be way off.
I will send you the old one, just email me a mailing address, and I'll see
if I can get a more accurate approximation of the required pressure.
Shona
