Clocking the prop. Real world data
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
kahuna
PostPosted: Tue Apr 17, 2007 5:52 am    Post subject: Clocking the prop. Real world data Reply with quote
After weeks of trial and error, I have finally reached a point where I can safely say that clocking the prop doesn’t just make a difference, it makes ALL the difference.
Several weeks ago I set out on a mission to run to ground a vibration in my RV-8. An IO-540 C4B5 with a Hartzell 2 blade prop. There has been a vibration that I would characterize as objectionable. Common on big engine Rockets and RV’s. The lower the RPM, the more objectionable it was.
I was able to instrument the plane and do some real tests and get real results with real data. The net of it is that by changing the prop clocking, I was able to improve my vibration by 83%. And no Im not kidding. You can read all the details here. http://www2.mstewart.net:8080/super8/index.htm
I captured a lot of data. I sure hope others find it useful. I have a new plane as a result.
Best,
Mike
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
