dhall(at)donka.net Guest
Posted: Thu Apr 19, 2007 9:45 pm Post subject: static line routing? |
I still have to do this step, and I'm about to paint the interior.
Is this article online somewhere? Or does someone have the
dimensions noted?
On Dec 10, 2006, at 7:25 PM, Greg Vouga wrote:
There is an article in the RVator (1st issue, 2006) detailing how
and where to rout the line through the cabin. The only hole you
will need to add is the one in the F-704 seatback bulkhead. They
recommend drilling a hole under the longeron just big enough to
pass the plastic static tubing through. No bushing is required.
If I remember correctly, the other holes are already punched in the
ribs from Van's. The punched holes are the correct size for bushings.
Greg
Raleigh, NC
RV-7 Wiring
> From: "LarryRobertHelming" <lhelming(at)sigecom.net>
> Reply-To: rv7-list(at)matronics.com
> To: <rv7-list(at)matronics.com>
> Subject: Re: static line routing?
> Date: Sat, 9 Dec 2006 20:46:50 -0600
> You route that forward just along/below the longerons on the pilot
> side of the plane. There are some holes already opened for you to
> route the line through. Indiana Larry
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Fri Apr 20, 2007 4:44 am Post subject: static line routing? |
It's in the FILES section on the Yahoogrooup. Seatback bulkhead, by the way,
is 705.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Posted: Fri Apr 20, 2007 6:17 am Post subject: static line routing? |
The "rv7 or 7a" group? Just submitted to that one, but there were several rv
groups on yahoo.
Don Hall
N517DG (registered)
rv7 fuselage
http://rv7.donka.net
Bob Collins
Posted: Fri Apr 20, 2007 6:51 am Post subject: static line routing? |
Here you go
http://groups.yahoo.com/group/RV7A/files/Newsletters%20and%20publications/
I also recall putting some pix in the photo section the last time this came
up but this morning I see Yahoo's photo section is up to its usual level of
dependability. I'll go snap some more before I head off to work and post 'em
here (if I can figure out how)
Bob
St. Paul, Minn.
Bob Collins
Bob Collins
Posted: Wed Apr 25, 2007 6:01 pm Post subject: static line routing? |
You da man, Bob. Thanks!
Don Hall
N517DG (registered)
rv7 fuselage
