Stuck Yak UPDATE.
MajorGoofinoff(at)aol.com
PostPosted: Thu Feb 09, 2006 5:10 pm    Post subject: Stuck Yak UPDATE. Reply with quote
OK,
   Here are the details so far.  YAK is HOME.
PostPosted: Thu Feb 09, 2006 5:40 pm    Post subject: Stuck Yak UPDATE. Reply with quote
OK, its official I hate AOL>
   Had a nice email and AOL screwed it up.
Scott.
      I checked both start switched today and found that each had power leaving the button when pressed.  I have to assume from this point on that it is the TKE 42 relay in the station 6 relay box.  I suppose it might be a broken wire just as it enter or exits the relay.  The combination of no power to the air solenoid and the shower of sparks really narrows it down.
      I did get my Yak home today.  Smile    I took an extra booster coil and wired it up with a pig tail so as to attach it to a 24 V battery charger and connected it to the lead going to the Mag. Tie wrapped it in place and ran the pig tail out the access door on the right side.  Hit the foot trigger on the air valve and my buddy flipped on the battery charger and bam!!! She lit right off.
      I think I will keep that booster coil in a box ready to mail at a moments notice.
Scott.
AKA Major Gooofinoff
Yak52
DFW area.
PS.  Email still welcome if you have any inputs.  I will be out of town for several weeks with my Air Force reserve unit later this weekend.  Yak is resting on its perch.
cjpilot710(at)aol.com
PostPosted: Thu Feb 09, 2006 5:41 pm    Post subject: Stuck Yak UPDATE. Reply with quote
Hmmmmmmmmmm.  Me thinks he found a switch?
OK,
