Rotax 377 and 477 use same points and ignition?
ElleryWeld(at)aol.com
PostPosted: Sat May 12, 2007 6:53 pm    Post subject: Rotax 377 and 477 use same points and ignition? Reply with quote
Kent
according to my CPS book the part numbers for the contact points set is Soldered part number is 983-349
Threaded part number is 983-343
these points will fit all engines 277,377,447,503
Good luck and I hope this helps you
Ellery do not archive
See what's free at http://www.aol.com. [quote][b]
PostPosted: Sat May 12, 2007 7:01 pm    Post subject: Rotax 377 and 477 use same points and ignition? Reply with quote
Kent
one more note the early engines prior to 1984 has the soldered  wire on the condensers (early) or secured by threaded post (late production)
Ellery in Maine
kentk
PostPosted: Sun May 13, 2007 5:56 pm    Post subject: Re: Rotax 377 and 477 use same points and ignition? Reply with quote
Very good! Thanks much for the help!
Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done
