Craymondw(at)aol.com Guest
Posted: Sat May 19, 2007 5:04 am Post subject: Service Bulletin 160 |
Replacing the AN364-428A nose wheel fork axle nut with a A365-428A doesn't give enough bolt threads and a longer bolt may be required. Note: When over torque, the wheel bearings start to bind up.
See what's free at AOL.com.
| - The Matronics Glasair-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Glasair-List |
s_korney(at)hotmail.com Guest
Posted: Sun May 20, 2007 4:00 pm Post subject: Service Bulletin 160 |
You can put shim washers inside and between the axle and the two aluminum
spacers and then the axle bolt and nut can be torqued to the proper spec
without binding the bearings......(note) I had to put about a .040 shim in
place...Now I tighten up the axle nut and the wheel bearings have the right
pre-load and the nut has the proper torque...
Best... Steve
----Original Message Follows----
Reply-To: glasair-list(at)matronics.com
Subject: Re: Service Bulletin 160
Date: Sat, 19 May 2007 09:03:15 EDT
************************************** See what's free at
http://www.aol.com.
More photos, more messages, more storage—get 2GB with Windows Live Hotmail.
