rocker arm bushings
Lynn Matteson
PostPosted: Mon May 21, 2007 6:23 am    Post subject: rocker arm bushings Reply with quote
I just did a 15 hour inspection of the rocker arm bushing job on my
2200 Jabiru, and all looks well. I had put some 2-3 hour trips on it
to try to get time built up so I'd have a chance to inspect it before
a much longer planned trip. The wear pattern looks good. I expected
to see a little more oil when I took the covers off, because I had
drilled out the oil delivery tube fitting orifice from .059" to .
063", but this didn't exactly flood the rocker area with
oil...enough, but not to the point of robbing the rest of the engine
of oil, to be sure.
The valve clearance setting had to be adjusted, but I expected this
due to a seating-in of the new bushings on the rocker shafts. I had
swapped the shafts across the engine so I could start fresh on a new
portion of the shaft. I'll check the clearances again in another
10-15 hours, just to be sure the clearances don't loosen again.
Lynn Matteson
Grass Lake, Michigan
flying w/293+ hrs
Lynn
Kitfox IV-Jabiru 2200
N369LM
Peter H
PostPosted: Mon May 21, 2007 1:38 pm    Post subject: rocker arm bushings Reply with quote
Good work Lynn congratulations on the initiative and the whole approach.
Peter H
Lynn Matteson
PostPosted: Mon May 21, 2007 5:42 pm    Post subject: rocker arm bushings Reply with quote
Thanks, Peter. With luck, this'll hold up well. Wish I knew why the
originals didn't...gremlins, maybe. : )
Lynn
On May 21, 2007, at 5:36 PM, Peter Harris wrote:
<peterjfharris(at)bigpond.com>
approach.
Peter H
Lynn
N369LM
