RV7A boarding
rafael(at)gforcecable.com
PostPosted: Tue May 29, 2007 5:20 pm    Post subject: RV7A boarding Reply with quote
I took my first ride in an RV6A last week and LOVED it! However, I was not pleased with the boarding procedure of stepping on the seat. I’m just starting my RV7A quick build and I don’t want this to be standard procedure with an expensive upholstery job.
Is there a way around this?
Cheers,
Rafael
pinkston(at)carolina.rr.c
PostPosted: Tue May 29, 2007 5:27 pm    Post subject: RV7A boarding Reply with quote
just put a hand towel in the seat's I had rv7a put on mine and it work's great, just shake it off from time to time randy pinkston flying 338 hrs rv7a
fvalarm(at)rapidnet.net
PostPosted: Tue May 29, 2007 5:40 pm    Post subject: RV7A boarding Reply with quote
Some builders lower the fuel selector knob about one inch so that it is just below the level of the top of the spar. Then put a little wing walk (anti-slip material) on the seat pan between the seats, directly behind the fuel selector (about 4" by 6" rectangle should do it). The lowering of the selector is so that it doesn't get bumped by your toes.
Bevan
Rv7A
finishing kit.
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Rafael
Sent: Tuesday, May 29, 2007 6:19 PM
To: rv7-list(at)matronics.com
Subject: RV7A boarding
Cheers,
Rafael
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
PostPosted: Tue May 29, 2007 5:42 pm    Post subject: RV7A boarding Reply with quote
Do you then sit on the hand towel, or pull it out after you get your feet onto the floor?
Bevan
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Randy Pinkston
Sent: Tuesday, May 29, 2007 6:26 PM
Subject: Re: RV7A boarding
redswing(at)mcn.org
PostPosted: Tue May 29, 2007 6:19 pm    Post subject: RV7A boarding Reply with quote
No, you just get a high wing airplane and avoid that problem and the rain inside too.
Red
PostPosted: Tue May 29, 2007 6:26 pm    Post subject: RV7A boarding Reply with quote
just sit on them,,,,they keep the plane clean inside,,just shake them off each time you put the great plane up randy p 705rp
PostPosted: Tue May 29, 2007 6:27 pm    Post subject: RV7A boarding Reply with quote
red who makes a high wing plane that comes close to the rv7?
walter(at)tondu.com
PostPosted: Tue May 29, 2007 6:32 pm    Post subject: RV7A boarding Reply with quote
> not pleased with the boarding procedure of stepping on the seat. I'm just
> starting my RV7A quick build and I don't want this to be standard
I spent a bit of $ for all leather seats. I've found that a small towel
placed on the seat and stepping on that works well. Just leave it there
and sit on it. If you don't like the looks of it throw them in the back
when you're at an airshow.
It keeps the seats clean and makes ingress/egress easier than stepping
between the seats, which is awkward for inseam challenged folks. This is
one of the minor penalties to having a small, fast aerobatic airplane.
You'll get used to it.
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
redswing(at)mcn.org
PostPosted: Tue May 29, 2007 8:06 pm    Post subject: RV7A boarding Reply with quote
those who build Wittman Tailwinds.
Actually, I like the RV series a bunch, was just trying to see if anybody was paying attention ; )
Red
PostPosted: Wed May 30, 2007 4:12 am    Post subject: RV7A boarding Reply with quote
we have 2 whittman tailwinds on our field ,,,that is a great plane & if I was smaller person it would be my next choice ,,,can't beat it for speed & price randy p 705rp rv7a flying
redswing(at)mcn.org
PostPosted: Wed May 30, 2007 6:42 am    Post subject: RV7A boarding Reply with quote
Yes, since you are building the structure, you cana make the cabin any size that you like, within reason. There are probably no two alike.
Red
franz(at)lastfrontierheli
PostPosted: Wed May 30, 2007 8:57 am    Post subject: RV7A boarding Reply with quote
Yes there is. It takes a while to figure it out but I never step on my seat cushion.
Franz RV7-60h
