RV-8 wheel landings
luckymacy(at)comcast.net
PostPosted: Thu Jan 05, 2006 5:54 am    Post subject: RV-8 wheel landings Reply with quote
So what are some safe ideas on moving the CG rear for first flights?
For example, if I wanted add 25 pounds to the rear baggage shelf and 50 pounds to the rear baggage floor, what are some safe ideas that won't hopefully lead to the ballast crashing through from the back and hurting me should I have an off field event.
Yeah, it's a generic question but folks who've been there know what I mean and that's who I'm targeting the question to. I'm interested more in actual solutions than future untried theories.
thx,
lucky
-------------- Original message --------------
ronlee(at)pcisys.net
PostPosted: Thu Jan 05, 2006 6:54 am    Post subject: RV-8 wheel landings Reply with quote
> For the first few flights, it may be wise to use some ballast to put
> the CG near the middle of the recommended range. After a few flights
> you can start adjusting the amount of ballast to slowly explore the
> forward and aft CGs.
> Kevin Horton RV-8 (finishing kit)
From my non-aeronautical engineer view that would not be ideal. As Kevin
noted, near the middle CG range is likely to be safer.
Ron Lee
wskimike(at)mchsi.com
PostPosted: Thu Jan 05, 2006 7:12 am    Post subject: RV-8 wheel landings Reply with quote
My suggestion is to bolt a little weight in the tail section to get the CG
where you need it. You can add lead weights in the tail and remove them as
necessary. You won't have to add so much gross weight. That is the way the
real world does it.
PostPosted: Thu Jan 05, 2006 7:13 am    Post subject: RV-8 wheel landings Reply with quote
This is why I wanted folks who've been there, done that to respond Wink
75 pounds spread out that way in the back gives MY configuration a middle CG AND that's wasn't really the main point of the quesiton anyway.
lucky
PostPosted: Thu Jan 05, 2006 8:25 am    Post subject: RV-8 wheel landings Reply with quote
Lucky, your original post talked about moving the CG "REAR" which
was interpreted as AFT. My reply was meant to urge caution which
was the intent of my post....safety.
Ron Lee
lucky
> Ron Lee
This is why I wantedfolks who've been there, done that to respond Wink
lucky
-- RV-List message posted by: Ron Lee <RONLEE(at)PCISYS.NET>
forward and aft CGs. <B
R>
Ron Lee
rv8_flyer(at)yahoo.com
PostPosted: Thu Jan 05, 2006 10:48 am    Post subject: RV-8 wheel landings Reply with quote
Lucky,
I made some tabs out of .040 AL that have a 1/2" hole on one end and a #8 hole on the other about 1" long with a 45 deg bend between the holes. I attached these to the #8 screws that hold the baggage area in place. Then I can attach tie down straps to them to hold everything in place. For the first few flights I strapped 25 lbs in the back to get the CG to the mid point. Had no trouble three pointing. But I have an O-320 so even solo with nothing in back my CG is an inch back from the fwd limit. I have no problem with full stall three point landings, but wheel landings are so easy in the -8 that is what I do if there is a crowd watching.
shempdowling2(at)earthlin
PostPosted: Thu Jan 05, 2006 12:27 pm    Post subject: RV-8 wheel landings Reply with quote
I purchased 2 bags of 25 lb. lead shot at a gun store. They are nice to
have around when you're not giving them a ride.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
kboatright1(at)comcast.ne
PostPosted: Thu Jan 05, 2006 3:18 pm    Post subject: RV-8 wheel landings Reply with quote
