f.miles.tcp.833(at)clearw Guest
Posted: Mon Feb 13, 2006 10:31 am Post subject: Preheating |
What is the conventional wisdom on preheating. I have K-lll w/ a Rotax 582.
With my Cherokee I have always preheated when the ambient temp. was 40
degrees F. or below. What is recommended for these little engines. I don't
think that it is matter of whether it will start but what is good for it.
Frank - Lewston, Idaho
jdmcbean(at)cableone.net Guest
Posted: Mon Feb 13, 2006 10:52 am Post subject: Preheating |
It is always better on an engine to pre-heat. There are a lot of
advantages... one is: the oil will circulate easier and get to the critical
areas better then when it cold and thick.
Fly Safe !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
wingnut
Posted: Mon Feb 13, 2006 12:05 pm Post subject: Re: Preheating |
What is the best (most effective) way to pre-heat?
algate(at)attglobal.net Guest
Posted: Mon Feb 13, 2006 12:55 pm Post subject: Preheating |
I use a small 110V auto interior heater purchased from Canadian Tire store
(about $25.00).
I put it in the front of the cowl and even at -20 deg C by the time I have
removed the covers from my plane it has put enough heat into the engine to
allow it spin easily and it starts every time.
I'm not sure if my posts are getting to the list and would appreciate it if
someone could confirm.
GaryA
Lite2/582
Posted: Mon Feb 13, 2006 1:14 pm Post subject: Preheating |
Gary, Appreciate your remarks. What I really wanted to know was at what
point do you decide to preheat and what engine do you have. The point has
been made that preheating is always good but there is a point of diminishing
return. The 582's do not have an oil reservoir like a normal four cycle, air
cooled, aircraft engine. I am sure that the point to preheat is an arbitrary
decision. What is yours?
rwill1(at)adelphia.net Guest
Posted: Mon Feb 13, 2006 3:50 pm Post subject: Preheating |
Pre heat below 40 F....!!!! We'd be preheating 6 months of the year in Maine.. When the temp gets -10 F , we just stay by the fire and self preheat...
DPREMGOOD(at)AOL.COM Guest
Posted: Mon Feb 13, 2006 5:26 pm Post subject: Preheating |
Loud and clear Gary,
Our local flying club has the same heaters installed in the cowlings of the
airplanes. What's more, they got Transport Canada approval to mount them onto
the airframe.
Doug Remoundos
Montreal
spaghettiohead(at)hotmail Guest
Posted: Mon Feb 13, 2006 6:01 pm Post subject: Preheating |
Usually don't get to pre-heat...never had a problem, but I don't usually fly
the 'Fox too much when it's below 30 anyway.
Funny thing, I was going to take my Crew Partner (Cockpit Resource Mgmt
Training in Multi-Engine Ops at school) flying low and slow...and the damn
battery turned the prop over once and kicked the bucket. NEVER had a problem
with it before...oh well. I hooked up the charger and started 'er up...
Any ideas where I can get a good, inexpensive replacement?
Thanks!
Andrew
KF3 582 68" GSC
| Quote: | From: "Rich Williamson" <rwill1(at)adelphia.net>
Subject: Re: Preheating
Date: Mon, 13 Feb 2006 18:48:16 -0500
preheat...
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
Posted: Mon Feb 13, 2006 9:36 pm Post subject: Preheating |
Just got a new battery from: Sport Plane, LLC. $71.50 + shipping.
I have heard it said that a starting a cold soaked engine at -20% C. without
preheating is equal to 200 hours of time on an engine. Frank
Posted: Tue Feb 14, 2006 8:10 am Post subject: Preheating |
200 hrs, ouch...I'll be flying the Cessna's and Arrows when it's that cold!
Thanks for the battery info!
Andrew
[quote]From: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Subject: RE: Preheating
Date: Mon, 13 Feb 2006 21:33:30 -0800
without
wingnut
Posted: Tue Feb 14, 2006 10:28 am Post subject: Re: Preheating |
Anyone use one of these?:
http://www.ultralightnews.ca/heaters/enginepreheater.htm
Seems like a simple and inexpensive setup that takes advantage of the fact that the motor is liquid cooled.
rjdaugh(at)rapidnet.com Guest
Posted: Tue Feb 14, 2006 2:18 pm Post subject: Preheating |
200 hours.
I think I avoid most of that by cranking until the oil pressure is up before
I turn on the mags. Then everything is pre-oiled before high RPM's.
My old Jeep has nearly 4000 hours on it and it doesn't burn any oil. And it
always is started with no oil pressure. And many of those starts are at
below - 4 F. Still, I suspect that there is some truth to the 200 hours run
of thumb.
Randy - 912S
aldaniels(at)fmtc.com Guest
Posted: Tue Feb 14, 2006 2:55 pm Post subject: Preheating |
There is a huge difference in air cooled and water cooled engines in how
a cold start affects them. The big no no is to cold start an air cooled
conventional aircraft engine as at cold temps the dissimilar metals
expand and contract at different rates and that reduces clearances to
less than acceptable. This is what causes the excessive wear. On most
car engines if you can crank it over enough to start and the oil will
flow you are all right. Multi weight oils have dramatically reduced cold
start oil starvation. It all comes down to what clearances the engine
was built with, what materials it was built with, and at what temp those
materials no longer have acceptable clearances. I would not start my
O-320 or O-360 below 20 F without preheat, and I would preheat below 30F
if I could, but I have never preheated my snowmobile - ever- and I have
started it at -20F and never had any sighs of problems. I guess you
would have to find out from the manufacture what the critical temps are
and go with that.
