[ExperimentalAvionics] Antenna doubler plate - prime or not
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
w_sweet(at)comcast.net
PostPosted: Sun Jun 17, 2007 6:42 pm    Post subject: [ExperimentalAvionics] Antenna doubler plate - prime or not Reply with quote
Do not use the cork gasket. Use RTV around the antenna base AFTER
installation. Also, the doubler will need to be riveted, and if solid rivets
(not blind rivets) are used, the doulber will be have a solid connection to
the aircraft skin.
Wayne
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
