david.allen(at)boeing.com Guest
Posted: Thu Jun 21, 2007 9:18 am Post subject: Skin riveting - making it pretty |
I started out at ground zero -- never even seen a rivet gun, let alone
used one -- luckily I had some friends who helped me get started.
Have now completed the tail, wings and half the fuselage on my 9A kit.
I had never been really satisfied with the cosmetics of the flush skin
rivets -- seems like there is always some slight deformation in the
vicinity of each rivet.
Somewhere along the line, it occurred to me that the only really
"pretty" rivets were those on the stiffeners that were back-riveted.
So I switched over to back-riveting everywhere possible -- using a
"dumbell" bucking bar (round with about 2" round knob on one end), the
standard 3" back-rivet set and a long offset back-riveter when needed to
get around rib or bulkhead flanges, etc. -- I got all these from Avery.
I'm now using the back-rivet process whether working alone or with an
assistant.
My assistant (wife) is a little intimidated with using the gun or the
bucking bar in the normal riveting process but seems to be much more
comfortable with the dumbell bar in the back-riveting process.
Communication between the two workers seems to be easier too -- the gun
operator can see immediate results of his actions, etc.
Bottom line is that I'm more satisfied with the results.
You old timers will probably be bored to death with this but hopefully
it will be helpful to the beginners -- I wish I could go back and re-do
some of my more visible skin surfaces.
Dave Allen
n616tb(at)btsapps.com Guest
Posted: Thu Jun 21, 2007 9:32 am Post subject: Skin riveting - making it pretty |
Hi David,
My back riveting on my -6 was also my best but in part due to the really
flat surface of the riveting plate on my bench. I found that riveting the
normal way worked OK so long as I pre tested my pressure settings. This was
the key for me. I also used only a 2x gun and that was helpful most of the
time. Can you share your experience about why you think you had difficulty
with riveting? Back riveting works great however so enjoy.
[quote] --
smittysrv
Posted: Thu Jun 21, 2007 11:58 am Post subject: Skin riveting - making it pretty |
Hi Dave,
Someone suggested to me at the beginning of my project to purchase a swivel
flush rivet set for my rivet gun. He told me that the swivel on this set
would cover my butt when I don't hold the rivet set perfectly perpendicular
to the skin when riveting and bucking.
http://www.smittysrv.com/toolpics/SwivelFlushRivetSet.jpg
Here's an entry on my website where I talk about the pros and cons of
backriveting with the 10 inch backriveting tool against using a flush rivet
set and rivet gun on the wing skins. I agree that the standard "short"
backriveting tool does great work and is indeed preferable when putting in
stiffeners. I also put rivet tape over every rivet that I put in.
http://www.smittysrv.com/more_stuff.asp?ID=438
Smitty
http://SmittysRV.com
Original Message:
Date: Thu, 21 Jun 2007 12:16:54 -0500
To: rv-list(at)matronics.com
Subject: Skin riveting - making it pretty
assistant.
Dave Allen
mail2web.com – What can On Demand Business Solutions do for you?
http://link.mail2web.com/Business/SharePoint
_________________ Smittys RV-9A
SmittysRV.com
dbris200(at)sbcglobal.net Guest
Posted: Thu Jun 21, 2007 1:16 pm Post subject: Skin riveting - making it pretty |
Dave,
You can get rid of those deformations pretty easily by tapping VERY
lightly on the shop head with no bucking bar on the other side. Where I
could, I used a universal head set in my rivet gun, otherwise a small
hammer will usually do the job. Using the universal rivet set tends to
just round off the shop head a little instead of smashing it. Be sure to
do a test first so you know how hard you're going to hit it.
Dave Bristol -6 So Cal
EAA Technical Counselor
EXT-Allen, David wrote:
assistant.
Dave Allen
