Quick build question
John Brunke
PostPosted: Fri Jul 13, 2007 7:04 am    Post subject: Quick build question Reply with quote
The quickbuild is truly a great head start towards an airplane. The only negative to it, is that you have to figure out what Van's has and has not done. Obviously that can be accomplished in a relatively short time. While going through the drawings yesterday and checking off what has been done, I noticed on Drawing 34 that there are 12 AN - 4 bolts that go through the F704 center section. While the top bolts will be easy to tighten, the bottom row will be a little "challenging". Just curious if any of you remember if these bolts were already in place when you got your
QB kit?
John Brunke
RV7 tip-up slowly moving along.
sshook(at)cox.net
PostPosted: Fri Jul 13, 2007 8:20 am    Post subject: Quick build question Reply with quote
I too would be interested as my QB fuse just arrived on Saturday
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of J. Brunke
Sent: Friday, July 13, 2007 09:04
To: rv7-list(at)matronics.com
Subject: Quick build question
QB kit?
John Brunke
lifeofreiley2003(at)yahoo
PostPosted: Fri Jul 13, 2007 8:50 am    Post subject: Quick build question Reply with quote
Take nothing for granted! Start at the front of each
section of the instructions for the wing and fuse if
QB and go through the motions. You'll need to know
these parts as things come together anyway.
Darrell
on Saturday
Scott R. Shook
RV-7A (Building)
N696JS (Reserved)
_____
Behalf Of J. Brunke
you got your
QB kit?
John Brunke
Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out.
http://answers.yahoo.com/dir/?link=list&sid=396545433
Bill Schlatterer
PostPosted: Fri Jul 13, 2007 5:08 pm    Post subject: Quick build question Reply with quote
John, I think I remember getting my wife to start the nuts as she could get her hand down in the center section. A long set of forceps would work too.
Bill S
7a
Sent: Friday, July 13, 2007 11:04 AM
QB kit?
John Brunke
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/Navigator?RV7-List
John Brunke
PostPosted: Fri Jul 13, 2007 9:31 pm    Post subject: Quick build question Reply with quote
Thanks Bill. I used an open end wrench with a piece of tape covering one end with the nut stuck inside. Then used a crescent wrench
to make an extension for the wrench. I had a good friend help me. The reason he's a good friend, was after we put on three bolts
this way, I realized that a washer gets put on the bolt side also. I think that's one of the few places I have seen that so far on the kit.
Of course we had the learning curve down by then and it didn't take quite as long to put them on a second time. It's funny how little things
like that all of a sudden "appear" on the drawing. At least it wasn't an expensive mistake.
John
