algate(at)attglobal.net Guest
Posted: Tue Feb 14, 2006 8:25 am Post subject: Cabin Heat |
I purchased the small cabin heater from Skystar and although it takes a bit
of the chill off your toes it does almost nothing to heat the cabin at -20
degC OAT. Dave Fisher (another Kitfox pilot) told me about his setup and it
works great.
I used a small Tupperware container (about 6" x 3") and drilled cut 2 x
1-1/2" holes in the bottom and then used two x plastic ties to strap it the
rear of my engine rad. From the two holes I ran two lengths of plastic shed
Vac hose up through the bungee openings into the cabin.
The heated air pumps out under your knees and brings the air temp up in the
cab about 20 degC. For even more heat he suggested a simple muffler heater
which ducts air into the cab at your feet and last weekend at -12 deg OAT it
registered + 15 in the Cabin.
GaryA
Lite2/582
wingnut
Posted: Tue Feb 14, 2006 10:23 am Post subject: Re: Cabin Heat |
Putting something behind the radiator will disrupt the airflow and reduce its effectiveness. Might not be a big deal in the winter but if you forget to take remove it during the summer, you could over heat your motor. A shroud sounds safer (isn't that what GA airplanes with air cooled motors use?) but I'd want a carbon monoxide detector in the cabin in case the mufler springs a leak.
How about one of those electric jump suits that mountain climbers wear? Don't have to mod your airplane and it will still keep you warm when you step out of the cabin.
Posted: Tue Feb 14, 2006 11:03 am Post subject: Cabin Heat |
Winter flying in Canada requires masking off the front of the Rad to reduce
cooling so this actually helps the situation. You wouldn't fly far in summer
with heater going as you would be uncomfortable to notice it.
GaryA
lcfitt(at)sbcglobal.net Guest
Posted: Tue Feb 14, 2006 11:58 am Post subject: Cabin Heat |
List
One quick question.
Who is Wingnut? Or are we not supposed to know, or are we just supposed to
not care?
I guess that was three questions, sorry.
Lowell
wingnut
Posted: Tue Feb 14, 2006 12:32 pm Post subject: Re: Cabin Heat |
I am wingnut. wingnut am I.
Was I supposed to make a formal introduction before I posted? Do I need credentials?
I'm a guy who recently purchased a kitfox and joined the kitfox list. I fly N824KF out of 34A (Laurens, SC). I have two kids, my wife likes horses, I wear 8 1/2 triple wides (yes I have duck feet). Some day soon, I'll have my very own 1500 ft grass strip behind my house and I think it would be cool if other airplanes came to visit (they don't even have to be Kitfoxes).
Posted: Tue Feb 14, 2006 2:46 pm Post subject: Cabin Heat |
Your name.
Most people sign their posts with their name. For some reason I like to
know who is posting. Call me old fashioned but I like to know all the names
of my friends. If your name really is Wingnut, then I apologize for asking
I checked the N# registry - no Wingnuts there.
Lowell
avidsid(at)yahoo.com Guest
Posted: Tue Feb 14, 2006 3:24 pm Post subject: Cabin Heat |
The standard factory cabin heat box supplied with the Avid comes with a shroud to mount behind one of the 582 cheek radiators and scat hosing to connect to the heater box mounted on the firewall. As the heater is opened up more, it dumps less and less out to the airflow through the cowling....less heat needed, more radiator heated air is dumped out the box and back into the cowling cooling flow..............simple, effective, and cheap, and no combustion fumes to worry about. Either setting, or something inbetween, allows full flow through the radiator for proper cooling.........
Sid
http://forums.matronics.com/viewtopic.php?p=12115#12115
Brings words and photos together (easily) with
wingnut
Posted: Tue Feb 14, 2006 4:03 pm Post subject: Re: Cabin Heat |
Quote: | Most people sign their posts with their name. For some reason I like to know who is posting. Call me old fashioned but I like to know all the names of my friends. If your name really is Wingnut, then I apologize for asking |
OK. You're old fashoned . The reason that Ken's name is still in the FAA database is that I've only recently purchased the airplane from him (Great guy BTW: He delivered my airplane accross the country for nothing but a return ticket home). Wingnut is just a login name. Everyone I see here uses an alias for that. If knowing my name makes you feel better then here you go.
Luis Rodriguez
Didn't meen to ruffle any feathers but I've been a citizen of the internet since before there was a world wide web and no one has ever asked me for my name before or suggested I was a friend because we posted on the same forum. To be honest, I'm kind of surprised and finding it hard to not be defensive... But, for the sake of friendship, I'm going to take your reasons at face value and throw in my address to boot:
244 Boyd Rd.
Laurens, SC 29360
Oh, and my birth day is in two days. Can I expect a card ?
rdmac(at)swbell.net Guest
Brett Walmsley
Posted: Tue Feb 14, 2006 8:29 pm Post subject: Cabin Heat |
Thanks Louis,
I think you will find that we here in the KF list are a friendly bunch and
we often respond with a Hi, (insert name) in the old fashioned way.
Lowell
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
tc9008(at)aol.com Guest
Posted: Wed Feb 15, 2006 6:05 am Post subject: Cabin Heat |
I'm in NC , glad to see someone close. I operate out of TDF in Roxboro, KItfox IV
Travis
MichaelGibbs(at)cox.net Guest
Posted: Wed Feb 15, 2006 7:24 am Post subject: Cabin Heat |
Wingnut sez:
Quote: | Didn't meen to ruffle any feathers but I've been a citizen of the
This is no ordinary internet forum, Wingnut. These are real people
being real in the real world, none of this anonymous cyber-reality
practiced elsewhere. Due to the nature and capabilities of our
shared interest, many of them have met and know each other
personally. They are not friends by virtual of posting to a forum,
they really are friends! At a Kitfox (or Avid) fly-in, nobody says,
"Hi, my name is quadmax." Many do not have 'net alter-egos and a few
probably don't even know what that means.
That said, it's a friendly and accepting group and you are most
welcome. Lowell may or may not send you a birthday card but either
way don't start feeling defensive. Before giving or receiving
safety-critical information, isn't it important to know something
about the source of that data?
I've met Lowell personally and I think you'd like him.
Mike G.
N728KF
Glenn Horne
Posted: Wed Feb 15, 2006 12:14 pm Post subject: Cabin Heat |
I think you are just a nut.
Glenn
Rex Hefferan
Posted: Wed Feb 15, 2006 2:53 pm Post subject: Cabin Heat |
Which one of us? Or both? :-\
Rex
Glenn
_________________ Rex
N740GP - M2/582
Colorado |
