Rudder Pulley Brackets
wjrhamilton(at)optusnet.c
PostPosted: Thu Jan 05, 2006 8:12 pm    Post subject: Rudder Pulley Brackets Reply with quote
John,
Thanks for that, your reply is reassuring, I will just keep the
inspections going.
Cheers,
Bill Hamilton.
At 13:47 4/01/2006, you wrote:
My 500B has 18,000 hours on it. My rudder pulley brackets are cracked.
Morris includes an inspection of them on his 100hr. inspection sheet. He
informed me that when they manufactured the brackets, they folded them but
didn't stress relieve the corners. He's seen multitudes of cracked ones, and
he says even the ones that haven't been stop drilled only crack to a certain
point. He says it's a problem he's been aware of only for the last 20 years
or so.
He is of the opinion that they probably cracked about 10 minutes after the
airframe was built (ok, maybe a little longer than that). He's also
mentioned that he's never *ever* seen or heard of one failing.
I guess I'll just continue to keep an eye on my pulleys, and see if anything
changes....
/John
CONFIDENTIALITY & PRIVILEGE NOTICE
W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet
Services and Warbirds.Net. & <wjrhamilton(at)optusnet.com.au>.
This message is intended for and should only be used by the
addressee. It is confidential and may contain legally privileged
information.If you are not the intended recipient any use
distribution,disclosure or copying of this message is strictly
prohibited.Confidentiality and legal privilege attached to this
communication are not waived or lost by reason of the mistaken
delivery to you.If you have received this message in error, please
notify us immediately to Australia 61 (0)408 876 526
Dolores capitis non fero. Eos do.
