Wade Lawicki
Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
Posted: Sat Aug 11, 2007 7:19 pm Post subject: Wiring diagram |
Group,
Anyone out there have a wiring diagram for their plane? I`m getting close to pulling wires and one would help a bunch with saving time.I have- 582, key west, electric start, fuel pump EIS, fuel level, 2 accy. plugs. Not sure of what size breakers of fuses to use, and never wired for a starter before? Any ideas?
Fly Safe,
Wade
_________________ Fly Safe! Wade
Nashville Tn.
FS 2 |
planecrazzzy Guest
Posted: Sun Aug 12, 2007 3:56 am Post subject: Re: Wiring diagram |
Hi Wade,
The starter won't involve you EIS or most of those other things.
It just cranks the engine.....You already have something that turns the
ignition on & off...
My GPL starter came with wiring instructions , to either run it to Ducati
dual ingnition w/start , or to just a plain start button.
Ground the starter , Hot wire from the Starter to the silenoid
then wires from the silenoid to the start button....
Do you want me to scan the papers and send them to you ?
it might help with wire guage sizes.... ?
Gotta Fly...
Mike & "Jaz" in MN
jindoguy(at)gmail.com Guest
Posted: Sun Aug 12, 2007 5:49 am Post subject: Wiring diagram |
Wade, all, Here on the Matronics list is a wonderful resource called the AeroElectric Connection. Run by a fellow named Bob Nuckolls, it is a treasure trove of his 40+ years as an avionics guru for manufacturers here in Wichita.
He publishes a manual, with the same name as the web site, that includes sample wiring diagrams in the appendices. Take a look at Figure Z-17, Small Rotax System. It's about as simple as can be done and eliminates the need for the constant draw of a battery contactor.
Rick
On 8/11/07, WADE LAWICKI <wlawicki(at)yahoo.com (wlawicki(at)yahoo.com)> wrote:[quote] Group,
Fly Safe,
Wade
[quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
