Key Switch for JAB 3300
pequeajim
PostPosted: Sun Aug 19, 2007 2:51 pm    Post subject: Key Switch for JAB 3300 Reply with quote
What key switch are you guys using with your 3300?
wypaul
PostPosted: Mon Aug 20, 2007 5:13 am    Post subject: Re: Key Switch for JAB 3300 Reply with quote
I used the ACS switch from Aircraft Spruce, but if I were doing it today I would just use toggle switches and a push-button. They are lighter, available anywhere and cheaper.
Paul Spackman
Q-2 3300 Jabiru
Paul Spackman
Q-2 Jabiru 3300
dredmoody(at)cox.net
PostPosted: Mon Aug 20, 2007 5:37 am    Post subject: Key Switch for JAB 3300 Reply with quote
I'm not flying my CH601XL yet but I second that suggestion. I went with an aircraft type key switch "Off, Right, Left, Both, Start" from ACS but if I were doing it again, I would use two toggle switches for the right and left mag and a start button. One obvious benefit is that when you are doing maintenance or daignostics, you can spin the engine with the starter while the mag switches are off. The key won't allow that.
Dred
Paul Spackman
Q-2 3300 Jabiru
Paul Spackman
Q-2 Jabiru 3300
http://forums.matronics.com/viewtopic.php?p=129933#129933
matronics(at)rtist.nl
PostPosted: Mon Aug 20, 2007 5:45 am    Post subject: Key Switch for JAB 3300 Reply with quote
Same here. The ACS switch does OK but is heavy and has some drawbacks.
The main drawback is that you can not run the starter engine for a few turns
with the magneto's off.
Rob
DanM
PostPosted: Mon Aug 20, 2007 10:53 am    Post subject: Re: Key Switch for JAB 3300 Reply with quote
I used a ASC switch also, but I bought the switch that is a off, left & right only model ,no start. I use a push button to start. This set up let me crank the engine with the mags off.
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
gaman(at)att.net
PostPosted: Tue Aug 21, 2007 5:34 am    Post subject: Key Switch for JAB 3300 Reply with quote
The security the switch gives is its best feature.You can easily wire from the master a second lead to a push button tied to the starter energize terminal.
G Aman kolb MK-3 2200
dredmoody(at)cox.net wrote:[quote] --> JabiruEngine-List message posted by:
Dred
---- wypaul wrote:
[quote] --> JabiruEngine-List message posted by: "wypaul"
craig(at)craigr.com
PostPosted: Tue Aug 21, 2007 6:16 am    Post subject: Key Switch for JAB 3300 Reply with quote
I had a Baron that didn't require a key but had a rotating key-like switch for the mags and starter. Since it didn't require a key, in order to provide some security there was a mic jack labelled COM3 inline with the starter. You had to insert a mic plug that had its tip and ring shorted to provide a connection for the starter. When you removed this plug the plane wouldn't start. Made it very difficult to steal. Smile
Craig
PostPosted: Tue Aug 21, 2007 8:00 am    Post subject: Key Switch for JAB 3300 Reply with quote
Thanks Craig, you have given me a good idea there. My key switch will of course provide the anti-theft protection since without it, the mags can't be turned on. I may use your shorted out 1/4" male mono plug as a more permanent way to activate the starter solenoid with the mags switched off.
I didn't like the idea of a permanently installed second starter switch because of the likelihood of activating it accidently. The extra jack labeled "Starter" could not be activated without having the shorted out plug inserted. That's enough safety for me, and as I said, it doesn't have to be camouflaged with a misleading label for security in my case.
Thanks again for the idea,
Dred
craig(at)craigr.com
PostPosted: Tue Aug 21, 2007 8:17 am    Post subject: Key Switch for JAB 3300 Reply with quote
I put the plug on a key chain that had the door keys on it so it was easy to
keep track of. It sure fooled the mechanics when I didn't leave the keys in
the airplane but instead handed them to them. I got more than one call (from
the same guy each time) telling me they had a problem they couldn't figure
out ... The plane wasn't starting no matter what they tried. Smile
Craig
