		john beirne
				 Posted: Sun Aug 26, 2007 2:22 pm    Post subject: Kitfox/582 coolant bleeding |
				I changed the coolant hoses that run to the cabin heater on my 582 engined fox and then refilled the system with coolant and bled the system at the vent on top of the thermostat until the coolant ran through, however now the engine overheats!
 Both rads get hot evenly over all their surfaces so I don’t think any air is trapped inside those
 I even placed the tail wheel on a barrel to ensure the cylinder head was level and prevent air entrapment inside the head while filling and bleeding
 What am I missing?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		malpass-architect(at)comc Guest
				 Posted: Mon Aug 27, 2007 4:50 am    Post subject: Kitfox/582 coolant bleeding |
				What are your cht numbers at a specific rpm range?
		Guy Buchanan
				 Posted: Mon Aug 27, 2007 7:54 am    Post subject: Kitfox/582 coolant bleeding |
				At 03:22 PM 8/26/2007, you wrote:
  	  | Quote: | 	 		  I even placed the tail wheel on a barrel to ensure the cylinder head
 What am I missing?
 Make sure there are no bubbles in the head. (Tilt, shake, bleed, run,
 repeat.) Make sure you bleed the pump housing, if you can. (Mine has
 ports top and bottom.) Make sure you're running 50/50 coolant /
 distilled water. Finally, were your old hoses so bad that they might
 have left chunks in the system?
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
		wheetfly(at)yahoo.com Guest
				 Posted: Mon Aug 27, 2007 8:34 am    Post subject: Kitfox/582 coolant bleeding |
				When I had my KF III 582 gray head I had to run 70%
 water to bring my temps 180deg. U mite try that 50% in
 winter
 Bill in maine
 --- Guy Buchanan <bnn(at)nethere.com> wrote:
  the cylinder head
  >What am I missing?
  shake, bleed, run,
  you can. (Mine has
  50/50 coolant /
  that they might
  Guy Buchanan
  San Diego, CA
  K-IV 1200 / 582-C / Warp / 100% done, thanks mostly
  to Bob Ducar.
  browse
  Subscriptions page,
  FAQ,
  Web Forums!
 Bill Wheet
 Buxton, Me.
 FsII 503
 Yahoo! oneSearch: Finally, mobile search
 that gives answers, not web links.
 http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
		Float Flyr
				 Posted: Mon Aug 27, 2007 9:24 am    Post subject: Kitfox/582 coolant bleeding |
				I usually fill the coolant,  start the engine and run it for about a minute, shut it down and check the  coolant level.  A minute should get all the bubbles out of the  system.  Make sure you have the breaker hose from the top of a cylinder  head looped back to the fluid filler.  That will remove any bubbles in the  heads.
  Noel
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		john beirne
				 Posted: Mon Aug 27, 2007 2:09 pm    Post subject: Re: Kitfox/582 coolant bleeding |
				Thanks guys
 The hoses removed were not in poor condition really, they were chaffed where they had been tie wrapped to the engine bearers loosely so “ a stitch in time”
 The coolant is a 10:1 distilled water and coolant (I live in a moderate climate)
 The engine never exceeded 75-80C even on a hot day, now it keeps climbing before I shut it down before it reaches 100C
 I have run the engine a number of times hoping it displaces the obviously trapped air and yet the problem continues.
 With the breaker hose removed from the head the coolant gushes merrily while filling, I've run about a quart over board so far
 The large hose from the pump to the thermostat feels soft as if  there may be air within
 Working on it tomorrow so will keep you posted
		malpass
  Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
				 Posted: Tue Aug 28, 2007 9:14 am    Post subject: Kitfox/582 coolant bleeding |
				Bill,  what is the highest cht temp you are running on a super hot day, with
 high density altitude?
 Reason I am asking because I have been running 192 (worst condition) on a 4
 minute climbout at 6500 rpm.  It then will come down to about 178 at cruise
 at 5200. I dont like the 192 degrees as the 582 grey head limits are suppose
 to be 180 max. I havent tried reducing the antifreeze but I have heard it
 helps cool the engine.  I also have double radiators in tandem under the
 belly.  Also have you heard anything about the orange stuff (for the
 greyhead) running any hotter than the green?
 Bill Malpass
  _________________ kitfox III w/ 582 greyhead |
		john beirne
				 Posted: Tue Aug 28, 2007 1:03 pm    Post subject: Re: Kitfox/582 coolant bleeding |
				I sorted the problem this evening by a combination of pipe massage and bleeding from the vent pipe held aloft and then plugging it with thumb before reconnecting quickly before it could draw in air all the while topping up the system- a four handed job- temps now 80 on the ground and sustained climb, 75 in the cruise- back to normal
 Thanks for all the advise.
