lynnp(at)c-gate.net Guest
lgreen1(at)sc.rr.com Guest
Posted: Thu Jan 05, 2006 2:09 pm Post subject: fuel sump |
Looks good Paul fine piece of work. Do not archive
Bryan Green (Elgin SC)
Posted: Thu Jan 05, 2006 2:13 pm Post subject: fuel sump |
Thanks Bryan,
Paul Petty
Building Ms. Dixie
Kolbra/912UL/Warp
www.c-gate.net/~ppetty
tombrandon(at)mac.com Guest
donghe(at)one-eleven.net Guest
jhauck(at)elmore.rr.com Guest
Posted: Thu Jan 05, 2006 5:38 pm Post subject: fuel sump |
| Good idea Paul, but I would would have kept the the drains
separate.
| Tom
Hi Tom/Gang:
I don't think Paul will mind if I respond to your suggestion.
Paul has looped the fuel line around the tail boom with the drain in
the bottom. Only has one fuel tank. So.......fuel is coming down one
side and back ukp the other.
I did this with my MKIII when I built it. However, I was not near as
fancy as Paul. Instead of the machined block of aluminum, I put a "T"
fitting, then ran a drain line forward to the lowest point of the
fuselage, which was between the gear legs. Near the end of the drain
line and inside the fuselage I installed a Briggs and Stratton nylon
fuel shut off valve. Works great.
Take care,
hauck's holler, alabama
Posted: Thu Jan 05, 2006 6:12 pm Post subject: fuel sump |
OOOPS!
Put my foot in my mouth. Sorry. I thought it had two fuel tanks.
Shows you I have a lot to learn. Some Kolbs have 2 tanks don't they?
Tom
separate.
| Tom
Hi Tom/Gang:
Take care,
Posted: Thu Jan 05, 2006 6:19 pm Post subject: fuel sump |
| Tom
Hi Tom/All:
Yes, the standard configuration for the Kolbra is two plastic jugs.
Same for the MKIII and the FSII.
Ten gallons won't get you very far, so a lot of us come up with much
larger fuel systems.
Take care,
MKIII
Titus, AL
Posted: Fri Jan 06, 2006 5:57 am Post subject: fuel sump |
Thanks Don. Wife's Idea? No way! This one wuz all mine!
Take Care
