Tim -Tunnel temps-an issue?
Deems Davis
PostPosted: Sun Feb 19, 2006 7:36 am    Post subject: Tim -Tunnel temps-an issue? Reply with quote
Tim, this issue has been on the minds of several of us since it was 1st
reported. What is your experience now that you are flying?
Deems Davis # 406
Fuse
http://deemsrv10.com/
Tim(at)MyRV10.com
PostPosted: Sun Feb 19, 2006 4:56 pm    Post subject: Tim -Tunnel temps-an issue? Reply with quote
I'm curious too. Let me get back to you on that. Today when I started
flying it was only 5-10F outside, so nothing was what I'd consider
hot. Wink Once I get more days that are 30F+ outside, I'll take my shoes
off and touch my toes to the tunnel.
Also, as a side note, if you look at some of my more recent FWF photos,
I have a 1.5" scat duct from the upper right side rear baffle that
goes down and turns parallel with the firewall, where it's clamped,
and it blows directly on the heater box valves. I also have 1/8"
silicone baffle gasket material as a standoff for those valves.
So, I don't expect mine to be hot....I already took steps to
prevent it.
Deems Davis # 406
Fuse
