Elevator position in cruise
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
matthew(at)n523rv.com
PostPosted: Mon Feb 20, 2006 6:19 am    Post subject: Elevator position in cruise Reply with quote
What are you flying RV-9'rs seeing for an elevator position in cruise? My counterbalance arm is sticking up may 3/4"-1" in cruise at 2500. Sure seems like a lot.
Can I fix that by adding a little more shim under the HS front spar?
Matthew Brandes,
RV-9A - N523RV
Hobbs: 15.3 Hours
www.n523rv.com
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
rv9jim(at)juno.com
PostPosted: Mon Feb 20, 2006 7:13 am    Post subject: Elevator position in cruise Reply with quote
Hi Matt,
First, is this in a lightly loaded situation. Or is it in a max
loaded situation? If this is a lightly loaded condition, then shim stock
under the tabs on the front HS spar mounts would be required. You are
trying to raise the tail in the present condition so raising the front of
the spar is called for. Remember that the tail is designed to provide
down loading in normal flight configuration. It seems as tho you have
too much down loading and your elevators are trying to reduce it by
providing a lifting moment. Try several shims of say .010 to .020
thickness. Try one and go fly. Continue to adjust until you have a
slight downward positioning of the control horn in a lightly loaded
condition. Then, as you load the aircraft up the trim will center up the
control horn on the tail and as you approach full load, the horn will be
slightly displaced upward. I hope that makes sense. BTW, "coke cans"
are aluminum and are thin enough to be used as shim stock. Just clean
off the material so you don't have a sugar coating on anything. Prime it
also. I would probably make several shims, clean and prime them and then
go after the adjustments to the horiz. spar.
Jim
RV9-A (QB)
PostPosted: Mon Feb 20, 2006 8:47 am    Post subject: Elevator position in cruise Reply with quote
Jim,
Yes, lightly loaded. It is me with 3/4 tanks. I'll make up a batch of shims and play with it some.
Matthew Brandes,
RV-9A - N523RV
#90569
www.n523rv.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
