Propeller bolts
cffd(at)pgrb.com
PostPosted: Mon Sep 24, 2007 8:01 pm    Post subject: Propeller bolts Reply with quote
My propeller bolts are AN4's (1/4x28). To change to AN5's (5/16x24), can I
just simply drill the holes in the bushings, crush plate and prop to 5/16?
Of course the prop holes for the bushings' OD won't change.
Chuck D.
N701TX
info(at)usjabiru.com
PostPosted: Tue Sep 25, 2007 5:40 am    Post subject: Propeller bolts Reply with quote
Hi Chuck,
Just drill the prop bushings and crush plate. We do it all the time to fit
Sensenich props with 3/8 holes to the Jabiru hub system.
Pete
Float Flyr
PostPosted: Tue Sep 25, 2007 6:39 am    Post subject: Propeller bolts Reply with quote
Before drilling any holes in the prop check with the manufacturer of the
prop. Why the change??
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
