drag issues and cowl suggestion
craigb(at)onthenet.com.au
PostPosted: Tue Sep 25, 2007 4:37 am    Post subject: drag issues and cowl suggestion Reply with quote
This may seem like an odd suggestion but has anyone
considered a setup something simmilar to the air intake
on the P51 mustang, but instead of air intake, use it for housing
of radiators. Clearly the design worked ok given the performance
of the p51, then the cowl could be steamlined as much as possible.
just a thought. Sure would look cool IMHO.
craig
1:27 PM
Trevpond(at)aol.com
PostPosted: Tue Sep 25, 2007 7:20 am    Post subject: drag issues and cowl suggestion Reply with quote
Hi Craig,
I had the "P51" type radiator on my ARV Super2 and it proved to be one of the biggest weaknesses on the whole aircraft. It was OK in the air but on the ground it proved to be a nightmare as there was no airflow unless there was a strong wind on the nose. When I was in a queue when leaving Cranfield, I had to park immediately behind a twin to keep the temperatures down!
regards
Trev Pond
G-LINN
