Increase oil pressure using washers?
matronics(at)rtist.nl
PostPosted: Wed Oct 03, 2007 9:06 am    Post subject: Increase oil pressure using washers? Reply with quote
MessageGood day,
With all the heated debate going on I hardly dare to ask... Wink
The Jabiru 3300 maintenance manual section 7.4.2 Sub-assembly B lists the
following advice to increase oil pressure:
"To increase oil pressure one or two AN4 washers can be placed behind the
relief valve
spring."
Silly question, but what is "behind" ? Does that mean the extra washer(s) go
in first into the crankcase cavity, or does the spring go in first and then
the washers?
Can anyone who has already done this comment on how much pressure gain you
can expect from a single or double washer?
Rob
Gilles.Thesee(at)ac-greno
PostPosted: Wed Oct 03, 2007 9:23 am    Post subject: Increase oil pressure using washers? Reply with quote
Rob Turk a écrit :
Does that mean the extra washer(s) go in first into the crankcase
cavity, or does the spring go in first and then the washers?
Rob,
Just as displayed in the book : washer, spring, plunger, valve seat,
circlip.
See
http://contrails.free.fr/images/Jabiru/relief.jpg
The Jabiru manuals are worth downloading.
Best regards,
Gilles
PostPosted: Wed Oct 03, 2007 11:10 am    Post subject: Increase oil pressure using washers? Reply with quote
Thanks Gilles.
I have the manuals, but this picture definitely isn't in any of the ones I
know. Where did you find this?
Rob
PostPosted: Wed Oct 03, 2007 1:39 pm    Post subject: Increase oil pressure using washers? Reply with quote
ones I know. Where did you find this?
http://www.usjabiru.com/Service%20Bulletin.htm
Click on 2200 Hydraulic Lifter Parts Manual
Best regards,
Gilles
ElleryWeld(at)aol.com
PostPosted: Wed Oct 03, 2007 2:04 pm    Post subject: Increase oil pressure using washers? Reply with quote
You should put the Ball in the crank case first then the spring then the cap with the washers in it last
Ellery in Maine
See what's new at AOL.com and Make AOL Your Homepage.
PostPosted: Wed Oct 03, 2007 2:22 pm    Post subject: Increase oil pressure using washers? Reply with quote
Rob,
3300 Solid Lifter Instruction & Maintenance manual section 8.6.1 page
45 shows the relief valve assembly
3300 Hydraulic Lifter Instruction & Maintenance manual page 43 shows same
Best regards,
Gilles
PostPosted: Wed Oct 03, 2007 2:39 pm    Post subject: Increase oil pressure using washers? Reply with quote
Ellery,
I have been following the Jab engine career for about 10 years, and as
far as I know the pressure valve has always been of the poppet/plunger
type on 2200s and 3300s.
Do you have a particular model or s/n in mind ?
Best regards,
Gilles
N1BZRich(at)aol.com
PostPosted: Wed Oct 03, 2007 4:49 pm    Post subject: Increase oil pressure using washers? Reply with quote
In a message dated 10/3/2007 1:07:23 P.M. Eastern Daylight Time, matronics(at)rtist.nl writes:
the washers?
Rob, Yes, the washers go in first. You will probably find one already in there, so you can add up to two more. My experience on my engine is that one AN4 washer will add 5 to 8 psi. Another couple of observations:
- if your oil temp is running on the high side, the oil pressure will be lower. Makes sense.
-if you keep the oil level in the sump so that it at the top of the dip stick range, your oil cooling will not be as efficient. I keep mine between the middle of the dip stick range to the bottom of the range.
Blue Skies,
Buz
See what's new atblank">Make AOL Your Homepage.
PostPosted: Thu Oct 04, 2007 3:39 am    Post subject: Increase oil pressure using washers? Reply with quote
Hi Gilles,
That explains. I have a solid lifter engine, so I never bothered to look at
the manuals for newer engines. I downloaded the hydrolic lifter parts
manuals just now, and the pictures are waaay better than those for my solid
lifter engine. Thanks!
Rob
PostPosted: Thu Oct 04, 2007 4:35 am    Post subject: Increase oil pressure using washers? Reply with quote
look at the manuals for newer engines. I downloaded the hydrolic
lifter parts manuals just now, and the pictures are waaay better than
those for my solid lifter engine. Thanks!
Rob,
Yes, the newer manuals show nice 3D drawings, but the older manuals,
(such as my 11 year old Maintenance manual) show them all the same,
albeit in 2D only.
What matters is you got your answer, and most important, we now all know
where to get up-to-date books Wink
Best regards,
Gilles
