E-185 scavenge pump housing
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List
n4546v(at)mindspring.com
PostPosted: Mon Oct 08, 2007 7:33 pm    Post subject: E-185 scavenge pump housing Reply with quote
Hello Listers:
On a E-185 series engine, the scavenge pump housing bolts onto the lower
front face of the accessory case with 6 bolts. In the parts book, no gasket
is shown. In the engine overhaul manual, the instructions tell how to
install it with no mention of gasket or other joint sealant.
Could someone in the know give me a short talk on how this housing is
installed where oil doesn't leak.
I have the intake spider and oil return tubes removed for regasketing to
cure some oil leaks, and am looking at the scavenge pump housing and
wondering if I should pull it and reseal it somehow while it's accessable,
but need more ifo. If it has no gasket, and uses no other sealant, what
kind of metal to metal fit does it have where oil doesn't leak.
Randy, Las Vegas
1948 Model 35
- The Matronics Beech-List Email Forum -
http://www.matronics.com/Navigator?Beech-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Beech-List All times are GMT - 8 Hours
