Riveting
bldgrv10450(at)comcast.ne
PostPosted: Tue Feb 21, 2006 6:34 pm    Post subject: Riveting Reply with quote
I have found great results using 2" packaging tape to cover and protect skins while riveting. I started with a tip from Randy Debauw using the packaging tape to cover the head of the swivel headed rivet set. Then I decided to try packaging tape on the skin for holding and (setting protection), works great. Anyone doing this? I use SOLVE cleaner by SEM to wipe the skins when complete.
Paul Grimstad
RV10 #450 closing elevators
ron.mcgann(at)baesystems.
PostPosted: Tue Feb 21, 2006 6:41 pm    Post subject: Riveting Reply with quote
Paul - yes good tip.  I have used the el cheapo plastic (rather than cloth) packing tape on my flush set extensively throughout the build process with excellent results.  Started out taping rivets, but found results were just as good with the tape on the flush set.  Also works brilliantly on a bucking bar when back riveting.
cheers,
Ron
[quote] --
Jim Carlton
PostPosted: Tue Feb 21, 2006 6:54 pm    Post subject: Riveting Reply with quote
Clear plastic tape? how thick? (mils) How about masking tape, would that
work?
LarryRosen
PostPosted: Tue Feb 21, 2006 7:18 pm    Post subject: Riveting Reply with quote
I use masking tape on my flush set. The blue type masking tape does not
last as long and the regular. I also use it on the sides of bucking
bars to prevent scratches.
Larry Rosen
http://lrosen.nerv10.c0m
work?
Larry Rosen
#40356
N205EN (reserved)
<http>
dlm46007(at)cox.net
PostPosted: Tue Feb 21, 2006 7:42 pm    Post subject: Riveting Reply with quote
The tape we use for virtually all aircraft work is
http://www.uline.com/ProductDetail.asp?model=S-10248&root=&searchedkeywords=s-10248
and no masking tape is not good for riveting; leaves a residue and is not
transparent.
jesse(at)itecusa.org
PostPosted: Wed Feb 22, 2006 6:44 am    Post subject: Riveting Reply with quote
We use clear tape (scotch tape, if nothing else is available) all the time, either when back riveting or on the rivet sets.  It works great.  Masking tape does not do as well on the sets from our experience, and it obviously won’t work well for holding the rivets in the hole unless you are back riveting on the plate because you can’t see the rivet.  We use Thinner to get the residue off.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Fax: 815-377-3694
I am in Ecuador until May, 2006.  If you have questions regarding I-TEC, please call the office at 352-465-4545.  If you would like to talk to me, please call me at 352-505-1899.  This number won't always be on, but it has voicemail that will get to me in Ecuador.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad
Sent: Tuesday, February 21, 2006 9:33 PM
Subject: Riveting
Paul Grimstad
