Engine Mount Alignment
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List
tcmoses(at)earthlink.net
PostPosted: Mon Oct 22, 2007 12:22 pm    Post subject: Engine Mount Alignment Reply with quote
Does any one have an electrical schmatic for the Allegro flap system? My flaps will go down but will not go back up.
- The Matronics Allegro-List Email Forum -
http://www.matronics.com/Navigator?Allegro-List
hgmckay
PostPosted: Wed Oct 24, 2007 5:18 pm    Post subject: Engine Mount Alignment Reply with quote
Tim:
<![if !supportEmptyParas]> <![endif]>
Yes, I have the schematic for the Allegro 2000 Flaps control connection. I will be glad to fax it to you if you will send me your fax number. Did you buy your Allegro as a used airplane? Do you have any assembly instructions? If so you might want to talk with the previous owner about the Flaps.
I do know that the flap control rod (vertical rod just behind the pilot) has too much “play” in it if you install it per the assembly instructions. The upper connection of this rod to the torque tube lever has too much axial rotation “play” due to the pivotal bearing used at that end. This allows the lower end where the drive screw is located to rotate slightly every time the flap motor is activated. It will rotate one way going up, and the other way going down. This slight rotation causes the attached leaf spring limit switch activator to rotate as well. If this rotation is enough it will rotate the leaf actuator enough to actually miss the limit switch. I had this problem. To solve it, I simply “shimmed” the upper connection with washers to end up with a “tight “ fit between the fork and the bearing (i.e. I took out the “play”). That solved the problem. Sorry, I can’t help you with your engine mounting problem.
Email me your fax and I’ll shoot the flap schematic to you.
Hugh McKay
Allegro 2000
Rotax 912UL
N661WW
hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)
-----Original Message-----
From: owner-allegro-list-server(at)matronics.com [mailto:owner-allegro-list-server(at)matronics.com]On Behalf Of TIM MOSES
Sent: Monday, October 22, 2007 4:22 PM
To: allegro-list(at)matronics.com
Subject: Re: Engine Mount Alignment
----- Original Message -----
To: allegro-list(at)matronics.com (allegro-list(at)matronics.com)
Sent: Monday, October 01, 2007 6:35 PM
Subject: Engine Mount Alignment
Has any one had a problem getting the engine mount level relative to the leveled fuselage (per the assembly instructions)? I currently have about 3.5 degrees of down thrust. If I shorten the upper mount supports, I am bending the lower engine rubber mounts quite a bit. Could the mount be bent from a hard landing? I did not build this plane. [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>href="http://www.matronics.com/Navigator?Allegro-List">http://www.matronics.com/Navigator?Allegro-Listhref="http://forums.matronics.com">http://forums.matronics.com<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Allegro-List Email Forum - --> http://www.matronics.com/Navigator?Allegro-List   - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
PostPosted: Wed Oct 24, 2007 6:10 pm    Post subject: Engine Mount Alignment Reply with quote
Hugh,
Thanks for the tip on shimming the flap push rod end. That is what I think caused my problem. It turns out that I had 2 broken limit switch wires. I have the flap connection drawing and instructions. What I was looking for was a real electrical schematic of the of the entire system, but it looks like it is no longer needed. In regard to the engine mounting problem...I ordered a new mount just to be sure.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Allegro-List All times are GMT - 8 Hours
