GX-60 - simulating speed on the ground
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
recapen(at)earthlink.net
PostPosted: Mon Oct 29, 2007 4:49 am    Post subject: GX-60 - simulating speed on the ground Reply with quote
Fellow tron-chasers,
I'm doing some autopilot testing in the hangar to make sure that things are commanded as designed.
One of the tests involves GPS steering (S-Tec System 30 with GPSS) and requires velocity to a destination in order to send proper signals to the steering converter.
Has anyone been able to get their GX60 to think it's moving in order to output roll signals?
Ralph Capen
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
gyoung
PostPosted: Mon Oct 29, 2007 6:05 am    Post subject: GX-60 - simulating speed on the ground Reply with quote
I don't know if it will do what you need but there is a simulator mode. It's
controlled by a jumper on the connector. Pin 7 on the 37 pin connector goes
to ground (pin 25) for normal operation. If open it's in simulator mode.
Greg Young
[quote] --
PostPosted: Mon Oct 29, 2007 6:16 am    Post subject: GX-60 - simulating speed on the ground Reply with quote
I'll look it up and try it - thanks
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
