marksorenson(at)sprintpcs Guest
Posted: Fri Jan 06, 2006 8:53 am Post subject: Yak Cooling grills |
Hello everyone,
I a new 55M owner and loving the heck out of this machine. However it is getting time to work on my front cooling actuating grills (if that is what they are called). Apparently they have been loose for a time and have elongated the holes in the ring so now they are not tight and set up a vibration as they flutter at high speeds when open.
Any leads on a parts supplier for this assembly. Feel free to e-mail me directly or the list.
Thanks.
marksorenson(at)sprintpcs.com
Best Regards,
Mark-
678-GO-FLY-HI
This message was sent from a Sprint PCS Phone.
Get a Sprint PCS Wireless Mail account!
Sign up via the Wireless Web Browser on your Sprint PCS Phone
or at http://www.sprintpcs.com.
rvfltd(at)televar.com Guest
Posted: Fri Jan 06, 2006 9:14 am Post subject: Yak Cooling grills |
Mark,
Two options, replace the inner ring (I have one IF it is the same as used on
M14 powered Yak 18T (I think it is), or Kelley Monroe just had his welded up
and redrilled. I am sure Kelley monitors the list so I think he will most
likely answer to you directly, if not email me and I'll give you his phone
number.
If you gills are as loose as you indicate you most likely need many other
parts also, like the cams on the end of the gills, inner ring screws, and
also the gill rotating rods, as these are all high wear points.
Email me a photo of your gills, I am pretty sure I can tell the type just by
looking at the photo.
Always Yakin,
Doug Sapp
kelmonroe(at)comcast.net Guest
Posted: Fri Jan 06, 2006 10:48 am Post subject: Yak Cooling grills |
I have not picked up the inner ring from the machine shop yet. I will get
it on 1/7/06 and I will reply after I am inspect it. Thanks Kelley
