Glasair-List Digest: 0 Msgs - 11/03/07
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
Craymondw(at)aol.com
PostPosted: Mon Nov 05, 2007 1:01 pm    Post subject: Glasair-List Digest: 0 Msgs - 11/03/07 Reply with quote
I was told that I may have high oil temps because of a broken ring. Other than a compression test, what other indicator would show this?
I decided to replace my oil cooler lines and used 303 hose ( a big mistake). As I used the mandrel to insert the hose and as I screwed in the fitting, the inside of the hose would bind and break away. I asked Aircraft Spruce if this batch was manufactured in China!!?
See w [quote][b]
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
jeffs(at)ostari.com
PostPosted: Mon Nov 05, 2007 1:35 pm    Post subject: Glasair-List Digest: 0 Msgs - 11/03/07 Reply with quote
http://www.sacskyranch.com/hosemistakes.htm
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com
Sent: Monday, November 05, 2007 12:59 PM
To: glasair-list(at)matronics.com
Subject: Re: Glasair-List Digest: 0 Msgs - 11/03/07
See w
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
