fuel shutoff valve
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
scottmain
PostPosted: Wed Nov 14, 2007 6:30 am    Post subject: fuel shutoff valve Reply with quote
Is the wheel well fuel shutoff valve supposed to cut fuel flow completely? If it is closed and the electric boost pump turned on, should ANY fuel continue to flow out of the fuel drain if open? I have tested mine after maintenance and some small amount still pumps out of the drain. It is only a small fraction of the flow with the valve open. I have several valves and they all seem to allow a small flow to the drain when closed. This is in a 1955 L26 by the way. Thanks to anyone who tests theirs and forwards the results.
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
