d-m-hague(at)comcast.net Guest
Posted: Thu Nov 15, 2007 6:35 pm Post subject: 2 stroke vs 4 stroke |
At 08:08 PM 11/15/2007, Richard Girard wrote:
The question of fuel injection came up at the Rotax Service Center
classes at Lockwood this last spring. Eric Tucker was asked, why it
wasn't used by Rotax. None available that meets Rotax reliability
standards.
Unless you could adapt an existing automotive fuel injection system I can
well imagine that the development cost for a reliable system would be
prohibitive.
From time to time I've played with the idea of developing an electronic
carburetor adjustment system for the small 2-strokes used on PPG's (nice
thing about a PPG is that an engine failure during testing is normally a
non event). My thought was to use an oxygen sensor in the exhaust to
measure the air/fuel ratio, and some electronics to drive an off the shelf
R/C servo to adjust the main mixture needle valve (most of these engines
use Walbro pumper carburetors). You could program it to keep as far on the
rich side of a stoichiometric ratio as desired. It would have to have a
failsafe mode, of course, to revert to a rich condition in the event of
failure of the O2 sensor, as well as during startup before the sensor is
hot enough to generate a signal (cars use heated sensors for startup, until
the exhaust is hot enough to keep the sensor hot, but they require too much
power for the lighting coil on a small engine).
On an engine with a float carburetor, it could control the mixture by
porting and metering manifold vacuum to the float bowl, similar to how the
altitude compensating carbs do it.
FAR simpler than true fuel injection, and mechanically simple... but
unfortunately a little beyond my own electronics skills.
Along those lines, has anybody tried the altitude compensating carbs
available for Rotax engines? Unfortunately they don't compensate for air
temperature as well...
-Dana
Of all the forces in the world, only the Federal Government has enough
power left to destroy America.
Richard Pike
Posted: Thu Nov 15, 2007 7:52 pm Post subject: 2 stroke vs 4 stroke |
Years ago, the guy that now has the 582 FSII in the hangar adjacent to
mine had a Hummer with a Zenoah 250 and a Mikuni pumper carb on it. We
rigged a long length of aluminum tubing from next to the seat back to
the high speed needle so that he could turn it in or out to adjust the
high speed needle according to what the EGT was showing. Anvil simple
and he never had an engine out.
Richard Pike
MKIII N420P (420ldPoops)
standards.
can well imagine that the development cost for a reliable system would
be prohibitive.
electronic carburetor adjustment system for the small 2-strokes used
on PPG's (nice thing about a PPG is that an engine failure during
testing is normally a non event). My thought was to use an oxygen
sensor in the exhaust to measure the air/fuel ratio, and some
electronics to drive an off the shelf R/C servo to adjust the main
mixture needle valve (most of these engines use Walbro pumper
carburetors). You could program it to keep as far on the rich side of
a stoichiometric ratio as desired. It would have to have a failsafe
mode, of course, to revert to a rich condition in the event of failure
of the O2 sensor, as well as during startup before the sensor is hot
until the exhaust is hot enough to keep the sensor hot, but they
require too much power for the lighting coil on a small engine).
the altitude compensating carbs do it.
air temperature as well...
-Dana
enough power left to destroy America.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu Nov 15, 2007 8:19 pm Post subject: 2 stroke vs 4 stroke |
At 10:50 PM 11/15/2007, Richard Pike wrote:
Quote: | Years ago, the guy that now has the 582 FSII in the hangar adjacent to
rigged a long length of aluminum tubing from next to the seat back to the
high speed needle so that he could turn it in or out to adjust the high
speed needle according to what the EGT was showing. Anvil simple and he
One of my PPG's has a Solo 210 engine (single cylinder, 14hp). No EGT, but
at the start of every day of flying it, I start it slightly rich, lean it
for peak rpm, then back off 100 rpm or 1/8 turn. In 350+ hours flying it,
I've had problems with engine accessories (muffler, ignition, redrive) but
never a seizure or any other trouble inside the engine.
-Dana
Balance the budget--declare politicians a game species.
Richard Pike
Posted: Thu Nov 15, 2007 8:23 pm Post subject: 2 stroke vs 4 stroke |
The recipe for all Experimental aircraft: Simplicate and add lightness.
Richard Pike
> to mine had a Hummer with a Zenoah 250 and a Mikuni pumper carb on
> it. We rigged a long length of aluminum tubing from next to the seat
> back to the high speed needle so that he could turn it in or out to
> adjust the high speed needle according to what the EGT was showing.
> Anvil simple and he never had an engine out.
EGT, but at the start of every day of flying it, I start it slightly
rich, lean it for peak rpm, then back off 100 rpm or 1/8 turn. In
350+ hours flying it, I've had problems with engine accessories
(muffler, ignition, redrive) but never a seizure or any other trouble
inside the engine.
-Dana
Kingsport, TN 3TN0
Jim Baker
Posted: Thu Nov 15, 2007 8:32 pm Post subject: 2 stroke vs 4 stroke |
X-SpamReason %%SpamReason%%:
Richard Pike
Richard has a sterling idea...but let's extend this out a bit.
http://www.acroname.com/robotics/info/ideas/continuous/continuous.html
There are some really powerful 1/4 scale servos out there that would
work nicely to control a needle. All one would need is the pulse
width generating electronics to control the servo....about $6 in
parts and $15 for the servo. An easy project, electronically. The
harder part would be building a servo mount. Perhaps a gear drive
set?
And then this......
Quote: | > The question of fuel injection came up at the Rotax Service Center
> standards.
Gee....hope Rotax doesn't hear about this.....
"Two-stroke, twin-cylinder Rotax®, Fuel Injection, R.A.V.E.TM exhaust;
Water cooled"
On what? SeaDoo GTi, Rotax powered.
Quote: | > Unless you could adapt an existing automotive fuel injection system I
> be prohibitive.
Now, I'm sure you'll try to tell me that JetSki engines are apples
and UL engines are oranges. Several other two stroke engine lines
have fuel injection: Fuji, Hirth, Orbital (especially Orbital),
Mercury, OMC, Bimota.....it's not hard to do, just not worth it in
the small volume world of UL sales. THAT is what Eric really means
but doesn't have the heart to say. I can't imagine that all these
companies would front all that research and $$$$, risking customer
loyalty, for an unreliable product....even Rotax.
Jim Baker
580.788.2779
Elmore City, OK
Jim ODay
Joined: 09 Jul 2007 Posts: 61 Location: Fargo North Dakota
Posted: Thu Nov 15, 2007 8:47 pm Post subject: Re: 2 stroke vs 4 stroke |
JetPilot wrote: | grantr wrote: |
What makes the 2 stroke less reliable than the 4 stroke? In theory the 2 stroke should be more reliable especially the piston port engine because it only had a few moving parts to fail.
Bottom line is if you want a reliable engine that is least likely to quit then its a no brainier, fly a 4 stroke.
If you can not afford a 4 stroke, and have no other option then to fly with a 2 stroke, do yourself a favor and read this article. Its short, and gives you really good useful, real world information (not a bunch of theory ) on how to keep your 2 stroke running as reliably as possible.
http://curedcomposites.netfirms.com/twostroke.html
Mike |
Good information on engines. Thank you! Can you point me to more reading on these engines? I am a novice on these little motors.
Can you recommend any video programs or books on operating the Rotax 2 cycle engine? A "Rotax 2 Stoke for Dummies" would be perfect.
I "can afford a 4 stroke"; what type of 4 stroke can be used on the Firestar, or is that not an option?
If 2 stoke is my only option, I have a 477, ...... is a dual ignition model more reliable? Or is it the proper tuning that is the primary key to good service?
Thanks.
Jim
_________________ Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot |
Posted: Thu Nov 15, 2007 9:07 pm Post subject: 2 stroke vs 4 stroke |
At 11:29 PM 11/15/2007, Jim Baker wrote:
Quote: | http://www.acroname.com/robotics/info/ideas/continuous/continuous.html
set?
Mechanically it's simple. You don't need continuous rotation, the needle
adjustment needed for weather or altitude changes is small, maybe 1/4 turn.
Quote: | "Two-stroke, twin-cylinder Rotax®, Fuel Injection, R.A.V.E.TM exhaust;
Water cooled"
> > be prohibitive.
have fuel injection...
I knew there were some outboards with fuel injection; I didn't realize
Rotax made any. If the development is already done, I'm surprised they
haven't applied it to the aircraft engines.
-Dana
When you were born, you cried and the world rejoiced...
Live your life so that when you die, the world cries and you rejoice.
-- Cherokee saying
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Fri Nov 16, 2007 3:53 am Post subject: Re: 2 stroke vs 4 stroke |
As far as a servo driver there's no need to reinvent the wheel.
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=3874
A standard servo with a gear drive would be more than enough to move a mixture needle.
http://www.servocity.com/html/mechanicals___accessories.html
[/quote]
set?
_________________ Scott
www.ill-EagleAviation.com
do not archive |
Posted: Fri Nov 16, 2007 4:10 am Post subject: 2 stroke vs 4 stroke |
At 06:53 AM 11/16/2007, icrashrc wrote:
Quote: |
As far as a servo driver there's no need to reinvent the wheel...
If I was just building a remote mixture control I wouldn't use electronics
at all; a simple push/pull cable would suffice. The electronics would be
needed to interpret the O2 sensor's signal voltage and move the servo as
required.
Some outfits sell O2 sensor driven display units. They don't control
anything, just display what the sensor is seeing. That might be a good
start, as a manual tuning aid and to see how the sensor holds up.
-Dana
Resist militant "normality" -- A mind is a terrible thing to erase.
biglar
Posted: Fri Nov 16, 2007 4:23 am Post subject: 2 stroke vs 4 stroke |
From what this 2 stroke beginner has read, the 2 main problems that
kill 2 strokes are mixture (heat) and lubrication. (mixture) Seems
like the ideas here could go a long way toward solving the mixture
problem, which would keep the heat and lubrication under control. A
pressure oiling system would bulletproof the lubrication problems.
Seems like I've read advertising somewhere (outboard motor mfr ??) that
2 stroke motors with pressure oiling systems have been built/are being
built. I realize that would run the weight up some and increase
complexity, but again, seems like the increased reliability would be
worth it and still lighter than a 4 stroke. Also, modern fuel injection
systems are extremely reliable.
Lar. Do not Archive.
Richard Pike
> standards.
> would be prohibitive.
> of failure of the O2 sensor, as well as during startup before the
> sensor is hot enough to generate a signal (cars use heated sensors
> for startup, until the exhaust is hot enough to keep the sensor hot,
> but they require too much power for the lighting coil on a small
> engine).
> how the altitude compensating carbs do it.
> -Dana
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Fri Nov 16, 2007 12:43 pm Post subject: Re: 2 stroke vs 4 stroke |
Engine freaks,
Here is a link to a very large two stroke engine. It also happens to be the most efficient internal combustion engine currently produced. It features pressure lubrication and direct injection. It wont fit on a Kolb, but you could fit several Kolbs into it.
http://people.bath.ac.uk/ccsshb/12cyl/
_________________ Roger in Oregon
1992 KXP 503 - N1782C
JetPilot
Posted: Fri Nov 16, 2007 2:45 pm Post subject: Re: 2 stroke vs 4 stroke |
Jim ODay wrote: |
Thanks.
Jim |
Hi Jim
The best engine for the Firestar appears to be the HKS 4 stroke engine. Dave Bigelow installed an HKS engine on his Firestar to fly over very hostile terrain in Hawaii, and has had very good luck with it. Although there is only one case of the HKS on a Kolb that I know of, Dave is very technically competent and has posted an about his setup on this forum:
http://forums.matronics.com/viewtopic.php?t=13013&highlight=hks
Trikes have been much faster to adopt the HKS engine, it is now the engine of choice on the more expensive Mid Sized trikes that are to small for a 912's. The reliability, and smoothness of this engine is well known in the many trikes flying this engine.
Mike
Kolb MK-III Xtra, 912-S |
JetPilot
Posted: Fri Nov 16, 2007 2:54 pm Post subject: Re: 2 stroke vs 4 stroke |
Jim ODay wrote: |
Thanks.
Jim |
I also fly a Trike with a 447 on it, and the main drawback of the 447 is the single ignition system. With a single ignition 447, a fouled plug, bad wire, cap comming lose, etc. etc. etc. will all bring you out of the sky. The engine might run on one cylender, but it wont produce a usable amount of power.
For a 2 stroke, a 503 is a more reliable choice because of the dual ignition systems. It has a little extra power which is nice also . As far as more info on 2 strokes, I use the Rotax books, and never exceed the limits they set. Another good thing is never run the 2 stroke at its full rated RPM. If you look at the power curve, max torque occours well below MAX RPM, and gives much less abuse to the engine. Try to get the last couple HP out of the engine with near limit RPM's, and your reliability and engine life well go WAY DOWN.
One good rule of thumb is to set your RPM for max power RPM MINUS 10 % static, which is close to 5900 RPM on a 503 and 447, and fine adjust from there according to the EGT's, and required power in the various phases of flight.
Mike
biglar
Posted: Fri Nov 16, 2007 3:44 pm Post subject: 2 stroke vs 4 stroke |
No link, Roger. Lar. Do not Archive.
R. Hankins wrote:
Quote: |
Engine freaks,
Roger in Oregon
http://forums.matronics.com/viewtopic.php?p=146468#146468
Palm Springs, CA
"Vamoose" |
russ(at)rkiphoto.com Guest
Posted: Fri Nov 16, 2007 5:19 pm Post subject: 2 stroke vs 4 stroke |
AIN'T NO LINK HERE!
On Nov 16, 2007, at 3:43 PM, R. Hankins wrote:
Quote: |
Engine freaks,
Roger in Oregon
jindoguy(at)gmail.com Guest
Posted: Fri Nov 16, 2007 6:14 pm Post subject: 2 stroke vs 4 stroke |
Jim, You see Rotax selling any ultralight engines with the R.A.V.E.
exhaust anymore? When those electronic fuel injection units have a
problem in a snowmobile, what's the worst that can happen? Then you
have the problem of powering them with a dynamo that's already
strapped for power output. The ignition systems use dedicated coils to
power them, where do you find the room to put in some more? Rotax goes
to great effort to engineer a light reliable engine. If they had a
fuel injection system of aircraft reliability and light weight, do you
think they would not offer it?
Yeah, all that snowmobile stuff is great, look at the difference
between the power of a 582 and a 583. more than 25% more power for the
583. How many successful 583 applications have you seen on an
airplane?
Hirth has been advertising fuel injection for around ten years, if it
were the next great panacea, don't you think you'd be seeing more of
them in the air?
Rick
> Richard Pike
set?
And then this......
> > standards.
"Two-stroke, twin-cylinder Rotax(R), Fuel Injection, R.A.V.E.TM exhaust;
Water cooled"
> > be prohibitive.
Jim Baker
580.788.2779
Elmore City, OK
Steve Boetto
Posted: Fri Nov 16, 2007 7:59 pm Post subject: 2 stroke vs 4 stroke |
In a message dated 11/16/2007 9:15:07 P.M. Eastern Standard Time, jindoguy(at)gmail.com writes:
Quote: | Hirth has been advertising fuel injection for around ten years, if it
them in the air?
It only Hirths for a moment
Steve B
Firefly 007/Floats
See w [quote][b]
lucien
Posted: Sat Nov 17, 2007 7:16 am Post subject: Re: 2 stroke vs 4 stroke |
JetPilot wrote: |
Hi Jim
Mike |
Actually the best engine for the FS is the 503, but putting that aside....
(add lots of smileys here)
The HKS does seem to be becoming successful and I'm gratified to see the Oleniks selling and supporting it. I had Tom do the 150 hour's on a couple of my 503's and there aren't better guys to work with than them. I think they know everything about ligh a/c motors than anyone.
I'm really glad to see it working well out in the field, as it'll give a good alternative right in a sore spot - the 60 to 65hp range....
PS: Now I'm going to say something _truly_ heretical:
I've been an ower-operator of the 912S for about a year now and am already finding myself wishing I was back to running a 2-stroke, specifically the 503, again.
I love the 912, it runs great and it gives no trouble, but the 503 is still simpler by a long ways to debug and maintain, and parts are so vastly, vastly cheaper (when you need them). And it also gives no trouble apart from the need for 150 hour's......
There, I said it - I'm a 2-stroke heretic not particularly impressed by the 4-stroke craze....
Alas, though, I've been told that Rotax is going to discontinue the 447 and 503 in a few years, so we may be stuck with the alternatives whether we like it or not .
LS
_________________ LS
Titan II SS |
Posted: Sat Nov 17, 2007 7:39 am Post subject: 2 stroke vs 4 stroke |
Lucien, It's okay to be a heretic. If you have the time, put Airbike
Ace into Google and read about Paul's adventures. He's a member of EAA
chapter 88 and flies his 503 equipped Airbike like most people fly
Cessnas. The story of his trip to Oshkosh this year is in the latest
issue of Sport Pilot. His 503 has over 650 hours and I don't think he
does anything but run it regularly.
As for the HKS, I have one on my trike, runs like a champ and sips
gas. I did 25 landings yesterday afternoon in two hours of flying and
it burned 4 gallons. Can't wait to get one on a Kolb.
Rick
On Nov 17, 2007 9:16 AM, lucien <lstavenhagen(at)hotmail.com> wrote:
Quote: |
JetPilot wrote:
> Hi Jim
> Mike
LS
LS
FS II
http://forums.matronics.com/viewtopic.php?p=146627#146627
JetPilot
Posted: Sat Nov 17, 2007 8:03 am Post subject: Re: 2 stroke vs 4 stroke |
jindoguy(at)gmail.com wrote: |
Rick
What kind of trike do you have Rick ? I fly an Air Creations Racer, I would love the buggy with the HKS and KISS wing, but they are way expensive new ! There don't seem to be any used ones on the market yet, which also says a lot
JettPilot
