Comm Antenna placement
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
recapen(at)earthlink.net
PostPosted: Fri Feb 24, 2006 8:01 am    Post subject: Comm Antenna placement Reply with quote
Fellow Listers,
I have a Comant bent whip com antenna that I am planning for the underside of my 6A.
I know that I want to keep it away from the exhausts so I was initially planning on installing it in the first bay outboard of the elevator pushrod tunnel - right under the copilot seat.
Where are the rest of you putting it?
Ralph Capen
RV6A N822AR (at) N06 90% done/to go
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
John Brunke
PostPosted: Fri Feb 24, 2006 4:11 pm    Post subject: Comm Antenna placement Reply with quote
Ralph,
I did not build my six, but the com antenna is mounted dead center of the
fuselage about six
inches back from the firewall. Aside from some oil residue from the
breather there have been no problems with this installation.
Every couple of preflights I just wipe off the antenna. The exhaust tubes
are spaced far enough apart that the antenna has
not been affected by heat.
John Brunke
215KC
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
