Autopliot & GPS Dilemma
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
FlyboyTR
PostPosted: Sun Nov 25, 2007 2:20 pm    Post subject: Autopliot & GPS Dilemma Reply with quote
I am wanting to add an autopilot to my plane. All the current units for experimental aircraft require a GPS to drive the system (so it knows where it's at). I use the AnywhereMap system with a Fujitsu tablet which has no output (NMEA). I read on the TruTrack web page that for non-GPS equipped aircraft they can supply a Garmin 35-HVA GPS receiver to drive the system. The 35-HVA works on 6-40 volts and has three wire leads (to be hardwired)...a positive, negative and the data line. TruTrack gets $175.00 for this receiver. I am looking for a less expensive alternative.
I can purchase any number of GPS receivers for less than $50...and actually already run two Bluetooth units in the plane (running two AnywhereMap systems). Does anyone have any suggestions on how one would tie in a generic GPS receiver? Thanks!
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
