handainc(at)madisoncounty Guest
Posted: Sun Dec 02, 2007 2:41 pm Post subject: King Handheld Adapter |
My King KX99 handheld radio adapter for Headphone is messing up. I took
it to a radio shop and all the connections were resoldered, but it still
only works about half the time - I suspect several breaks in the wires.
A friend gave me his adapter that came from another type of radio. It
has the two plugs for the headset end but also has the push to talk
wired into the adapter (the King used a plug that inserts into on of
the headset plugs). The other end of the adapter has the correct small
mini plug for the "Phones" jack. However the other connector to the
radio was a screw on type. There are two wires in that cable, one
larger than the other, both with a center insulated wire and a
multistrand surrounding which I assume is shielding.
I know very little about wiring, as I am sure this message
demonstrates! My question is how do I wire the two wires to the
mid-sized miniplug to go to the KX 99? That mini-plug has a tip contact
area, a second contact are a little further back and the shaft contact
area which I assume is the ground.. The plug receptacle on the radio
is marked "MIC".
Anyone have a wiring diagram for the KX99 and adapter or can give me an
idea on how to wire the mini-plug to the mic receptacle?
M. Haught
