912ULS: Carburettor and Airbox venting lines
Martin Pohl
PostPosted: Sun Dec 16, 2007 2:56 am    Post subject: 912ULS: Carburettor and Airbox venting lines Reply with quote
I am going to install the Rotax 912ULS in my CH601XL soon. The new installation manual from BRP-Rotax (Version 1 / Rev. 0, May 01/2007) is quite straightforward, nevertheless I do still have some questions:
- The manual states on page 92 that the carburettor venting lines should be routed into ram air or vacuum free zone or into the airbox. Drawing 59 shows the connection between carburettor vent and airbox. Ok, I understand that...
- Then the manual states on page 102 that the airbox venting line should be also routed into ram air or vacuum free zone OR INTO THE AIRBOX. Well, the drain is FROM the airbox, how comes that I should reroute TO the airbox???
What is common practice? Connect carburettor vent to airbox and then airbox vent to some place below?
Thank you for any advice!
Cheers Martin
CH601XL HB-YNA
Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html
gfmjr_20(at)hotmail.com
PostPosted: Sun Dec 16, 2007 6:33 am    Post subject: 912ULS: Carburettor and Airbox venting lines Reply with quote
Martin--
I ran both my airox and carb vents separately down the engine mount into the slipstream.
George May
601XL 912s 174hours
Subject: 912ULS: Carburettor and Airbox venting lines
Date: Sun, 16 Dec 2007 02:56:52 -0800
To: rotaxengines-list(at)matronics.com
--> RotaxEngines-List message posted by: "Martin Pohl" <mpohl(at)pohltec.ch>
Cheers Martin
CH601XL HB-YNA
Martin Pohl
Zodiac XL QBK
http://forums.matronics.com/viewtopic.php?p=152487#152487
&g========================>
Get the power of Windows + Web with the new Windows Live. Get it now! [quote][b]
Roger Lee
PostPosted: Sun Dec 16, 2007 9:17 am    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Hi Martin,
I have a Flight Design CTSW and the carb vent lines run into the airbox and all other lines from there run down and out under the bottom cowling just barely in the air stream. (oil vent line runs out at the same area)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Martin Pohl
PostPosted: Sun Dec 16, 2007 9:26 am    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Thank you for your answers!
I was just wondering if it is a wise idea to run the pressure sensitive carb vent lines into the slipstream. Homebuilt.org and I think also Lockwood say it is not the best setup.
Nevertheless you don't seem to have troubles with this configuration. I will follow Roger's instructions.
Cheers Martin
Martin Pohl
Zodiac XL QBK
Roger Lee
PostPosted: Sun Dec 16, 2007 3:45 pm    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Hi Martin,
My hoses come down inside the cowling and actually stop right at the bottom. They don't actually protrude out into the slipstream, but right up to it.
Roger Lee
Tucson, Az.
Cell 520-349-7056
Martin Pohl
PostPosted: Mon Dec 17, 2007 9:36 am    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Roger, that sounds fair! I will do it the same way.
Thx and cheers
Martin
Martin Pohl
Zodiac XL QBK
N601RT
PostPosted: Mon Dec 17, 2007 10:00 am    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Martin and Roger,
(This is my first posting to this list. I've been lurking for a while.)
Be very careful of routing the carb vent lines. I personally saw a CH701 have significantly reduced power from routing the carb vent lines to the bottom of the cowl. Everything was fine during ground testing, but the plane would barely climb. Changing the vent line back to the original length solved his problem. There have been reports of others having problems with other installations where the vent line was improperly extended.
(Remember this is a vent line as you have properly discussed; It IS NOT a fuel overflow line.)
I took the Rotax Maintenance course at California Power Systems that Eric Tucker taught in early 2005. Eric stressed the importance of making sure the pressure at the vent line is the same as the pressure around the carb. He specifically said DO NOT extend the vent line to the bottom of the cowl as this has the chance of reducing the pressure the vent line senses and can prevent the carb slide from opening fully.
I've routed standard length vent line into a much larger tube which goes to the bottom of my cowl. There is about 3/4inch of the smaller line in the larger line. This allows any fuel that might come out of the vent line to flow into the larger line AND it allows the vent line to have the same pressure at the carb.
Roy
N601RT: 2002 CH601HDS, nose gear, Rotax 912ULS, Arplast PV-50, All electric, IFR, equipped, 895hrs
Roger Lee
PostPosted: Mon Dec 17, 2007 5:07 pm    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
I agree that the vent lines are not supposed to be in the slip stream, but just down by the bottom of the cowling, but still inside should be fine.
Roger Lee
Tucson, Az.
Cell 520-349-7056
rparigor(at)suffolk.lib.n
PostPosted: Mon Dec 17, 2007 6:09 pm    Post subject: 912ULS: Carburettor and Airbox venting lines Reply with quote
Just a note on 912/S:
Increase float bowl pressure over ambient pressure = richer mixture
Decrease float bowl pressure below ambient pressure = leaner mixture
As a matter of fact these guys sell a kit that allows you to decrease
float bowl pressure (lean mixture) by pulling a vacuum through a needle
valve (or automatic) via manifold cross over tube:
http://www.greenskyadventures.com/bing/HACmanorder.htm
Choose an area in cowl that is ambient pressure on ground and especially
in flight. One good location is just downstream of air filter, or go
measure chosen location on ground and in flight (climb, dive, go fast and
slow, flaps and clean).
Ron Parigoris
BTW 914 is a different beast, you need to vent float bowl to air-box
pressure (to accommodate turbo charging). As a matter of fact, for 115%
914 power operations the TCU rich-ens the mixture a little by plumbing
float bowl pressure via a solenoid from air-box pressure to above air-box
pressure (scoop in air-box airstream that increases pressure). None the
less theory of increasing float bowl pressure above some value to richen,
and decreasing float bowl pressure below some value to lean is the same as
912/S.
MAKE SURE FLOAT BOWL PLUMBING IS FREE OF RESTRICTIONS OR LEAKS ON ALL
9XXs.
Tommy Walker
PostPosted: Sat Dec 22, 2007 4:08 pm    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Roy,
Do you have a picture of your vent line setup that you could share?
Many thanks,
Tommy Walker in Alabama
N8701
N601RT wrote:
Martin and Roger,
Roy
Tommy Walker
N25A - Anniston, AL
N601RT
PostPosted: Wed Jan 02, 2008 2:47 pm    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Tommy,
Here is a photo of one vent line going into a larger line in my plane. I drilled a small hole in the top of the larger line near the end of the original length Rotax vent line, just to be sure the vent sensed the local pressure.
(Sorry for the delayed response, I've been away for the holidays.)
Happy New Year
Roy
912 Carb Vent extension
 Filesize:  28.38 KB
 Viewed:  1024 Time(s)
Martin Pohl
PostPosted: Thu Jan 03, 2008 12:03 am    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Roy, thank you for sharing the photo of your venting line and your information about routing of the line.
Happy new year to all of you!
Cheers Martin
Martin Pohl
Zodiac XL QBK
Tommy Walker
PostPosted: Thu Jan 03, 2008 3:54 am    Post subject: 912ULS: Carburettor and Airbox venting lines Reply with quote
Roy,
Thanks a lot. I got the pictures and from what I can see you have a well put together engine. Does the larger tube run down to the slip stream?
Tommy Walker
N25A - Anniston, AL
N601RT
PostPosted: Fri Jan 04, 2008 6:43 pm    Post subject: Re: 912ULS: Carburettor and Airbox venting lines Reply with quote
Tommy,
I ran the larger tube to the bottom of my engine mount, close to the firewall attachment. The tube does not extend below the cowl.
Roy
N601RT: 2002 CH601HDS, nose gear, Rotax 912ULS, All electric, IFR equipped, 895hrs
