		| Author | Message |
		| sandford(at)melbpc.org.au Guest
				|  Posted: Fri Jan 04, 2008 3:05 am    Post subject: auxillary fuel tank |   |
				| Craig
 Dave McCandless in Perth W.A. Oz has done this. He has a 30 ltr tank in
 each wing.
 Unfortunately Dave has developed an intolerance to epoxy and his kit is
 up for sale.
 I did once have a sketch of his arrangement. If anybody is interested, I
 may be able to find it in my too hard basket.
 I did not proceed with it because I have wiring conduits through the
 wing ready for closure.  If I donīt call a halt to new mods I will never
 get to fly.
 Lance Sandford in Oz
 craig bastin wrote:
  	  | Quote: |  	  | Not sure if this has been brought up before, but has anyone done wing tank/tanks. Seems to me a tank of about 15 litres a side would fit ok,
 and could be
 plumbed in with the same bulb primer arrangement as the strap in tank
 and use  the dry break coupling found on most boats to plug the line
 in as you put the wings
 on. Also (correct me if i am wrong) would the tank and fuel not become
 part of the wing dead weight and so not add to G loading weight for
 those who like to fly at "Unusual Attitudes"
 from time to time.
 craig
		| Back to top |  |
		| davidjoyce(at)doctors.org Guest
				|  Posted: Fri Jan 04, 2008 7:32 am    Post subject: auxillary fuel tank |   |
				| Ian, I was referring here to the LongRanger tank fitted to Europa
instructions, which when in use drains fuel at the same time from theLR &
 main tanks. The standard fit for the inbuilt plane tank of course has no
 such problems, unless you make the mistake of running from full with the
 selector on reserve! (which I guess wouldn't foul the VLA regs anyway).
 Regards, David Joyce, G-XSDJ
		| Back to top |  |
		| rampil
				|  Posted: Sun Jan 06, 2008 12:47 pm    Post subject: Re: auxillary fuel tank |   |
				| FWIW the Hill accident report is now complete and may be read at NTSB.gov.
The NTSB ID is LAX07LA148.
 Some detail about the marine aux tank is given. The 914 revealed no
 possible pre-crash malfunction although that conclusion could not be
 definitive due to the post-fire effect.
 No probable cause was determined
 BTW, while the Oshkosh incident was due to slow airspeed in the base to
 final turn, both aircraft fell from about 300 feet agl and I would not use
 "slow" to describe the impact velocity and deceleration of either.
 Ira N224XS
		| Back to top |  |
		| gregoryf.flyboy(at)comcas Guest
				|  Posted: Sun Jan 06, 2008 2:56 pm    Post subject: auxillary fuel tank |   |
				| Both of these planes must have hit at quite a speed.
 The tank seems of durable type.
 Interesting that in the report, the number of seats in the plane was listed
 as 3. I assume this is a typo.
		| Back to top |  |
