Rotating Beaecon: Re: More 150 parts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Cessna-List
n1345p
PostPosted: Thu Feb 07, 2008 11:56 am    Post subject: Rotating Beaecon: Re: More 150 parts Reply with quote
D,
I've only installed these in place of a rotating beacon, not a flasher. Both my 150's have flashers and we've replaced both the bulbs and flasher units when they quit working with new faa/pma aeroflash units.
The rotating beacons were in older, 50's model airplanes.
ACS sells the stuff to replace the 70's cessna aero-flashers.
http://www.aircraftspruce.com/catalog/elpages/aerofanticol.php
and they are FAA/PMA.
mitch
Subject: Re: More 150 parts From: "n1345p" <n1345p(at)suddenlink.net> Date: Jan 30, 2008
I wouldn't mess with repairing a rotating beacon - unless I for some reason really wanted to keep it.
I have replaced these as a minor repair with something like this:
http://www.aircraftspruce.com/catalog/elpages/fs4400.php
mitch
C150J,L
http://forums.matronics.com/viewtopic.php?p=161498#161498
Date: Jan 31, 2008 From: "D Wysong" <hdwysong(at)gmail.com> Subject: replacing beacon w/ strobe on C150
> mitch
> C150J,L
Hello Mitch.
Thanks for the info on the tail strobe. I have a couple of questions if you
can spare a few moments...
For mounting in the C150L did you have to purchase the adapter ACS sells,
too?
What about wiring in the C150L? Did you have to run new wires from the
panel? Did you use the same breaker, a new breaker, or the "fuse" they have
listed?
Finally, any issues getting the 337 for this component past the feds?
Thanks again for your time and the helpful info, Mitch.
D
C150M
From: "Barry Davis" <bed(at)mindspring.com> Subject: Re: More 150 parts Date: Jan 31, 2008
That's OK for a Cessna 180, but not legal or STC'd for a 150?
Barry
- The Matronics Cessna-List Email Forum -
http://www.matronics.com/Navigator?Cessna-List
Mitchell Williams OKPE, ATP/CFI/A&P/IA www.chickashawings.com
of shadow and ash http://www.amazon.com/dp/B009KZGVQS
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Cessna-List All times are GMT - 8 Hours
