		rampil
				 Posted: Sat Feb 09, 2008 8:46 am    Post subject: Disappointment in Rotax 9 series |
				Hi All,
 I have been a big fan of my 912uls since I started flying with it three
 years ago. Part of the reason was the modern carb design in the Bing 64
 with automatic (at least partial compensation for altitude in the) mixture.
 All their advertising states this.
 Well, unless someone can prove the following data wrong now, this
 Altitude compensation is a complete crock.  I really hope someone
 has some data to prove this wrong.
 I just happened upon the new Katana DA20-100 POH with official
 performance charts of the certificated 912 and 912S engines. The AC
 also has a Hoffman CS 2 blade prop.  The charts clearly show
 progressive increase in fuel flow with altitude at a set %max power.
 This is of course the exact opposite of Lycomings and Continentals
 and the Rotax/Bing claims.
 Can someone please show me how this interpretation is wrong (no
 handwaving please, just documented facts).
 Maybe the GreenSky HAC or real fuel injection is the way to go!
 I attach some charts which show the data
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		|  Description: |
		|  Filesize: |
		 52.41 KB |
		|  Viewed: |
		 876 Time(s) |
		|  Description: |
		|  Filesize: |
		 477.18 KB |
		|  Viewed: |
		 2223 Time(s) |
		jstewart(at)jkmicro.com Guest
				 Posted: Sat Feb 09, 2008 9:22 am    Post subject: Disappointment in Rotax 9 series |
				rampil wrote:
 Hi All,
 Are you sure you have the right charts?  The second chart
 shows a range of  1900 - 2380 RPM which seems unlikely
 for a 912.
		ami(at)MCFADYEAN.FREESERV Guest
				 Posted: Sat Feb 09, 2008 11:26 am    Post subject: Disappointment in Rotax 9 series |
				As part of some recent testing of a different propeller, a full power climb
 from 2500' to 6500'+ showed constant RPM and EGTs all the way.
 Fuel flow dropped steadily from 4.0 Imp GPH to 3.7 Imp GPH.
 This suggests to me that the mixture was altitude compensating between those
 altitudes. The reduction in fuel flow was consistent with a reduction in
 engine power resulting from the lowering air density; not to be confused
 with mixture.
 But this was with a constant throttle opening (WOT), whereas the DA20
 figures are for increasing throttle opening, necessary to maintain the
 stated power level at the different altitudes.
 Duncan McF.
		rampil
				 Posted: Sat Feb 09, 2008 12:34 pm    Post subject: Re: Disappointment in Rotax 9 series |
				Followup-
 JStewart:  Think prop rpm, not engine RPM
 NB:  The data I appended was for the DV-20-100, not the DA-20
 engine is the rotax 912S3
 Just off the phone with Bud Yerly about this.  He recounted a flight test
 recently with no measured fuel flow, but with EGT declines with altitude.
		imap8ntr(at)cox.net Guest
				 Posted: Sat Feb 09, 2008 1:29 pm    Post subject: Disappointment in Rotax 9 series |
				Hi
  The best "factual" data is what I  have as my experience.  I have owned a 912UL for about 4 years and  definitely it does not have an altitude compensating carburetor.  As I go  up in altitude I must allow for increased fuel usage. As I go from 2000 ft to  9500 ft I increase my fuel consumption by 20%.  This makes sense to me  since I am burning richer as I go up in altitude.  The new LSA's have the  Bing compensating carburetor and thus no mixture control.
  My Jabiru engine has the Bing  compensating carburetor.  As I go up in altitude I dont see much change in  my EGT because in stead of the engine running richer,  the carburetor  compensates to keep the mixture the same as evidenced by a contant EGT.  So  I know for a fact that the Bing compensating carburetor works well as  stated.  I dont know why Rotax states the fuel cosumption is increasing  with altitude.  My engine does the opposite and I run most efficiently at  high altitude on my cross countries.
  Hope this helps. I  have not  been pleased with Rotax support as a whole.  Certainly there have been so  many service bulletins out regarding the 912 that I almost wish I had my old 582  back.
  Ivan
				 Posted: Sat Feb 09, 2008 1:46 pm    Post subject: Disappointment in Rotax 9 series |
				Ivan a écrit :
  	  | Quote: | 	 		   I have owned a 912UL for about 4 years and definitely it does not have
 Ivan,
 Would you care to elaborate on the "compensating" and "non compensating"
 carbs ?
 As far as I could see, there is no particular difference between the
 Bings 64 on the Rotax, and the Bing 64 on the Jabiru. Also, except for
 the particular engine jetting, there is no apparent technical difference
 between the carbs in each engine documentation : the Jabiru manual shows
 the same picture as the Rotax.
 In my opinion, the Bing carb provide *some degree* of altitude
 compensation due to the constant vacuum design.
 Best regards,
 Gilles
 http://contrails.free.fr
		rampil
				 Posted: Sat Feb 09, 2008 7:35 pm    Post subject: Re: Disappointment in Rotax 9 series |
				Hi Gilles,
 I think you are an experienced thoughtful guy,  but what does it mean
 to have an opinion on these carburetors <"In my opinion, the Bing carb provide *some degree* of altitude compensation due to the constant
 vacuum design. ">.  On the other hand, what you told Ivan is absolutely
 true from my hands on experience with both engines,
 We are not talking about health food nonsense or placebo. We must talk
 engineering, these are deterministic systems, they either work
 or they do not work.
 The DATA says they do not work, in fact, they perform WORSE
 than just leaving full rich on a Lycoming.
 I may well be wrong due to lack of sufficient data, but the DATA
 so far says the 912S3 is CONTRACOMPENSATING.
 Please explain to me my error.  Opinions can not count
 Has anyone performed actual, careful engine performance flight
 test.  I'd like to, but my new EFIS  has the output of my FloScan
 bouncing all over creation to the point where it is unusable.
 Does anyone have DATA to share?
		Thom Riddle
				 Posted: Sun Feb 10, 2008 5:38 am    Post subject: Re: Disappointment in Rotax 9 series |
				rampil,
 I do not know where you got your data but attached is a snapshot of the cover page from my Katana Manual and the page with the performance and fuel consumption table data.
 See attachments.
 As you can see there is nothing indicating a variance in fuel flow AT A CONSTANT POWER SETTING regardless of variations in altitude.
 Per my training, knowledge and experience, fuel flow is a nearly linear function of power being produced, regardless of altitude at which it is being produced. I have never had a fuel flow meter on any of the airplanes I've owned with the 912 series engine but have flown a good bit of cross country time in them at known power settings at widely varying altitudes, and the fuel required to fill the tank after these flights has always been within 1/2 gallon of my projections based on time and power setting during these long continuous power flights at varying altitudes. Also, the EGTs on my 912 read pretty constant at a constant power setting at varying altitudes.
 Thom Riddle
 Retired Mechanical Engineer
 FAA Certificated Powerplant Mechanic
 http://riddletr.googlepages.com/a%26pmechanix
		|  Description: |
		|  Filesize: |
		 127.16 KB |
		|  Viewed: |
		 841 Time(s) |
		|  Description: |
		|  Filesize: |
		 78.42 KB |
		|  Viewed: |
		 860 Time(s) |
		rampil
				 Posted: Sun Feb 10, 2008 6:06 am    Post subject: Re: Disappointment in Rotax 9 series |
				Hi Tom,
 Again, the data was for the DV-20-100 912S3
 not the DA-20 912.
 Yes my DA-20 manual looks the same (I have about 150 hours in them)
 but the manual does not specify what altitude the measurement was
 made, and since my time was in a rental, I did not bother to try.
 Re the DA-20 manual, certainly you dont believe the carbs compensated
 up to the max altitude of 13000?  Nobody I spoke every claim claimed
 they compensated for altitude over 8000, including Eric Tucker who
 I spoke to at Oshkosh 2005 at some length when he was hanging out at
 the CPS booth.
 Unrepentant Electrical Engineer
 AME Eastern Region
		Thom Riddle
				 Posted: Sun Feb 10, 2008 7:15 am    Post subject: Re: Disappointment in Rotax 9 series |
				rampil,
 I appreciate your bringing this increased fuel flow with increased altitude data to us. It was news to me and a bit of a surprise. The good news is that at higher altitudes you get higher TAS with a given power setting, which helps compensate for the increased fuel flow.
 If my current airplane were certificated experimental I would be tempted to try the adjustable mixture control (HACman) that you mentioned. But then again, most of my current flying is at low altitudes so it might not be an economical solution for me anyway. I'm happy that I can run methanol free 87 octane autogas in our 912UL and burn between 4.0-4.2 gph at 75% power.
 I still like the 912 series better than any other engine I've flown with.
 _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		hagargs(at)earthlink.net Guest
				 Posted: Sun Feb 10, 2008 10:31 am    Post subject: Disappointment in Rotax 9 series |
				The carbs on my Europa are almost indistinguishable from the carbs on my
 old BMW pushrod motorcycle.  So there should be no moaning and groaning
 that you are not getting "altitude compensating" carbs.  What you have are
 "constant velocity" motorcycle carbs.  Those diaphrams on top of the slides
 keep you from opening up the bores too much for the mass of air that can
 flow through them and get a relatively good mixture.  Supposedly to give
 you better or smoother throttle response when cranking it on a motorcycle.
 As noted  before fuel consumption is directly related to hp produced.
 Leanable carbs only reduce fuel consumption by allowing you to keep the
 gas/air (oxygen) ratio proper (stoiciometric?).  You can keep the throttle
 wide open.  What you probably get with the bings is the  fact at altitude
 the  mass of air going through at altitude will not allow the diaphrams to
 pull the slides up all the way even though the throttle is opened up fully.
 The 914 shouldn't care as it should think it is at sea level to 16K I
 believe.
 Steve Hagar
 A143
 Mesa AZ
  	  | Quote: | 	 		   [Original Message]
  To: <rotaxengines-list(at)matronics.com>
  Date: 2/10/2008 8:21:21 AMa
  Subject: Re: Disappointment in Rotax 9 series
 <riddletr(at)gmail.com>
  rampil,
  Thom Riddle
  N221FA Allegro 2000 912UL
  N197BG FS1/447
  Believe nothing, no matter where you read it or who has said it, not even
 if I have said it, unless it agrees with your own reason and your own
 common sense.
		hdwysong(at)gmail.com Guest
				 Posted: Sun Feb 10, 2008 10:35 am    Post subject: Disappointment in Rotax 9 series |
				 	  | Quote: | 	 		  Has anyone performed actual, careful engine performance flight
 Hello Ira.  We saw the same erratic behavior out of our FloScan and EFIS (MGL RDAC-X).  The solution was to pull the signal line (white wire) up through a resistor to clean up the signal.  I'll send you a sketch of the schematic if you're interested.
 D
		rampil
				 Posted: Sun Feb 10, 2008 1:36 pm    Post subject: Re: Disappointment in Rotax 9 series |
				Hi D,
 Thanks for the offer. Supposedly the EFIS I have has a 10k ohm
 pullup to the 5v rail internally. A pullup makes sense when the
 optical transistor inside the Floscan does not generator enough
 voltage swing on it's collector.  I don't think that is the problem in my
 case, but I will check the waveform with my scope.
 I think my problem is that the company has a strange idea of how
 much digital filtering (smoothing after conversion  from pulse interval
 to flowrate) they do to this particular signal.
		rampil
				 Posted: Sun Feb 10, 2008 1:53 pm    Post subject: Re: Disappointment in Rotax 9 series |
				Steve,
 I think we both know what a carb is supposed to do.
 You are just off track when you compare aircraft to motorcycle
 applications.  I cant think of the last time I gunned my rotax throttle
 at the stop line
 The constant "depression" in Euro-speak or constant pressure in USA
 English is in fact supposed to provide altitude compensation, the goal
 in the case of the Rotax, to run just rich of peak at all altitudes.
 This is the stated and advertised goal of using the Bing 64 instead
 of a single conventional carb.
 What is in fact happening is that the engine IN FACT is running richer
 and richer with DA when it should should reduce fuel flow to match the
 reduced air mass charge.
 As for increased TAS with DA, well you don't need a Rotax for that!
 A rubber band motor will do exactly the same thing!
				 Posted: Sun Feb 10, 2008 2:20 pm    Post subject: Disappointment in Rotax 9 series |
				rampil a écrit :
  Hi Gilles,
  to have an opinion on these carburetors .  On the other hand, what you told Ivan is absolutely
 Ira,
 Not sure what your point is, but what I'do first is double check the
 printed data.
 Especially when they seem indicate something contrary to engine physics.
  	  | Quote: | 	 		   Please explain to me my error.  Opinions can not count
 I may have missed something, but could you provide a link to this
 particular manual ?
  	  | Quote: | 	 		   Well, unless someone can prove the following data wrong now, this
 I'd say it the other way "unless you can prove our engines and carbs are
 wrong, these data you're referring to are not reliable".
 Best regards,
 Gilles
		jetboy
				 Posted: Sun Feb 10, 2008 2:22 pm    Post subject: Re: Disappointment in Rotax 9 series |
				I would like to add here that although the carbs used on the 912 are similar to those on the Jabiru, the Jabiru ones now have a much different profile needle which gives the standard Continental / Lycoming aero engine profile of leaner mixture below 75% power and progressively richer above 75%.  This saves 1 or 2 litres/hr of fuel flow over the original needle profile. Above 8,000 feet the needle should not be able to enrich the mixture even at full throttle setting although I have not tested this recently. they wont be able to compensate above this altitude however the Jabiru needle keeps a much leaner mixture due to the different taper.
 You might consider purchasing more appropriate needles for the 912.
 Downloading the latest Jabiru SB-18 gives good guidance.
 Ralph
  	  | Gilles.Thesee(at)ac-greno wrote: | 	 		  Ivan a �crit :
 Ivan,
 carbs ?
 Best regards,
 Gilles
 http://contrails.free.fr |
 _________________ Ralph - CH701 / 2200a |
		rampil
				 Posted: Sun Feb 10, 2008 2:45 pm    Post subject: Re: Disappointment in Rotax 9 series |
				Gilles,
 I wish it were so simple as to have wrong data.
 Here is the URL you seek for your own official copy straight
 from Austria.
 http://www.diamond-air.at/dv20_afm_bas+M52087573ab0.html
 I refer you to page 73 in the PDF corresponding to page 5-04 on paper.
				 Posted: Sun Feb 10, 2008 3:39 pm    Post subject: Disappointment in Rotax 9 series |
				rampil a écrit :
  	  | Quote: | 	 		   I wish it were so simple as to have wrong data.
 Ira,
 Had a look at the manual.
 Concentrated on the 75 % power numbers. The 8000 ft numbers are in close
 agreement with every other 100 hp Jabiru/Rotax engine : in the 22-23
 L/hr ballpark. At this altitude, 75 % power is obtained with full
 throttle and max allowable RPM. Nothing wrong with those data.
 Now at lower altitudes, one can choose between different MP/RPM
 combinations. The lower the RPM and the higher the MP, the lower the
 fuel burn for a given % output. So it is normal to burn *less* at those
 settings. Any atmospheric engine behaves like that.
 So I'd rather say : at lower altitudes it is possible to burn slightly
 less fuel for a given % output. At 1000 ft you also can use the 8000 ft
 settings. You'll burn a little more fuel because you'll be at part throttle.
 But at 75 % any atmospheric 100 hp engine will burn about 22-24 L/hr at
 8000 ft : Lyc, Conti, Rotax, Jabiru or whatever.
 At 75 %, our 914 (same carbs) burns around 22 L/hr.
 Best regards,
 Gilles
				 Posted: Sun Feb 10, 2008 4:46 pm    Post subject: Disappointment in Rotax 9 series |
				Gilles
 Supposedly the "altitude compensating carburetor" is one that self
 compensates for changes in atmospheric pressure and adjusts the fuel flow
 accordingly.  Thus even without a mixture control as you go up in altitude
 with a constant power setting the carburetor compensates and decreases the
 fuel flow,  thus giving the engine less fuel when there is less oxygen and
 thus doesnt let the mixture get rich but keeps it about constant.  This has
 been my finding on my Jabiru 3300 since the EGT(a measure of mixture) stays
 about the same as my altitude is increasing.  There is a little error due to
 different temperatures from day to day which thus a colder day with the same
 barametric pressure can lean out the mixture slightly as evidenced by
 slightly higher EGT's for that day.  The carburetor ONLY compensates for air
 pressure and not air temperature(which indirectly may affect pressure.)
 And that is the way I see it as evidenced by by EGT probes.  My fuel usage
 is basically constant at about 5.1 gal/h on cruise at 75% power (2850 RPM)
 on my 120hp engine.
 Hope this lightens things rather than confues them,
 Ivan
 Phoenix,  AZ
				 Posted: Mon Feb 11, 2008 4:48 am    Post subject: Disappointment in Rotax 9 series |
				Ivan a écrit :
  	  | Quote: | 	 		   Supposedly the "altitude compensating carburetor" is one that self
  flow accordingly.  Thus even without a mixture control as you go up in
  altitude with a constant power setting the carburetor compensates and
  decreases the fuel flow,  thus giving the engine less fuel when there
  is less oxygen and thus doesnt let the mixture get rich but keeps it
  about constant.  This has been my finding on my Jabiru 3300 since the
  EGT(a measure of mixture) stays about the same as my altitude is
  increasing.  There is a little error due to different temperatures
  from day to day which thus a colder day with the same barametric
  pressure can lean out the mixture slightly as evidenced by slightly
 Ivan,
 Thank you for clarifying your opinion.
 The point was, there is no technical difference between the Bing 64
 carbs on a Rotax vs a Jabiru.
 Both provide *some degree* of altitude compensation.
 BTW, just for the fun, the cutaway drawing in the Jabiru documents was
 borrowed from...a Rotax manual
 But no problem here, since the Rotax drawing comes direct from Bing, and
 the carb internals are the same.
 Best regards,
 Gilles
