aprazer
Posted: Wed Feb 20, 2008 2:29 pm Post subject: 601XL Canopy |
Ladies and Gents;
I have decided to glue the broken triangular piece back onto the canopy instead of purchasing a new canopy for $550 and then go through all the trouble of trimming, drilling, etc...
To cover the damaged area, I have decided to revert back to the old way of doing things by installing a metal flashing on the front of the canopy.
This is where I need the help from someone!
Does anyone have the dimensions for this front flashing? My plans are too new and don't show this flashing.
Any and all help will be greatly appreciated.
Mack
N990MK
CH601XL/Jabiru3300
_________________ The poh-oh-unemployed farm boy from Idaho |
bryanmmartin
Posted: Wed Feb 20, 2008 2:44 pm Post subject: 601XL Canopy |
I don't have my plans handy right now but you could just lay a piece
of craft paper up there and trim it to fit and use that as a pattern
for the metal.
Ladies and Gents;
the canopy.
Mack
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Wed Feb 20, 2008 3:21 pm Post subject: 601XL Canopy |
My oldest set of plans lists .025, 210 X 1600, 6-C-3, 05/01. Same on the
01/03 version.
-- Craig
zodierocket(at)hsfx.ca Guest
Posted: Thu Feb 21, 2008 5:04 am Post subject: 601XL Canopy |
XL owners, I need a favor. Can you hop in your plane and measure the
distance from the top of the arm rest 6-B-18-2 where it meets the center
back seat channel 6-B-16-2 and measure the distance between that spot
and the top of the rear Canopy frame 6-C-3-1 where the plastic is joined
to the alum tube. Please measure to the forward side of the tube while
the canopy is in the closed position. I realize the tape measure will
have to bend to reach. Also can you check the height of the arm rest to
the highest portion of your canopy. Each of us have fitted this
differently but I am curious as to the variance and If there is a base
measure to help others in the future. I would use mine for this but I
have installed an older 601HD canopy and it is a different shape then
the 601XL's.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
2/18/2008 6:49 PM
aprazer
Posted: Tue Feb 26, 2008 5:32 am Post subject: Re: 601XL Canopy |
I want to thank every one for their input on the canopy flashing.
There are some good ideas out there probably because the plans are so vague!
I’ve got a lot of work cut out for myself, but labor is cheaper than the $550.
Again, thank you all once again,
Mack
