Firewall foreward cooling air needs
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List
recapen(at)earthlink.net
PostPosted: Mon Feb 25, 2008 6:01 am    Post subject: Firewall foreward cooling air needs Reply with quote
Here's the setup:
IO360B1F6 with CS MT prop, AFP injection, LASAR ignition, Vetterman crossover heater/mufflers in a SamJames cowled/plenum'd RV6A.
I'm planning on putting the oil cooler behind the #4 cylinder with its cutout for airflow feeding the oil cooler.
My heater/mufflers require cooling air over them even when they're not heating the cockpit according to Larry.
I'm thinking that taking the cooling air for both heater/mufflers from the back plate behind the #2 cylinder should be OK - since I'm taking a chunk from each side.
Is this a valid thought? - or does it not matter since I have a plenum.
For the cabin heat air, would it be better to take the air from the vertical plate or the 40 degree angled plate below it?
Ralph
- The Matronics LycomingEngines-List Email Forum -
http://www.matronics.com/Navigator?LycomingEngines-List
aurbo(at)ak.net
PostPosted: Mon Feb 25, 2008 6:48 am    Post subject: Firewall foreward cooling air needs Reply with quote
Ralph,
I did not know that the heat muffs required cooling air flowing over
(through?) them at all times. Why is that?
I just installed my carb heat yesterday and I used another one of Van's heat
muffs instead of the standard issue carb heat gizmo. I elected to get the
carb heat air from inside the cowl instead of cutting another hole for it in
the air inlet ramp. That is the way Cessna and the standard Van's carb heat
muff does it and it seems to work just fine.
For the air supply to the heat muff for cabin air I went even lower and took
the air from the plate right next to the cylinder fins. I and others have
thought this is a good place because the air will be pre-warmed as much as
possible.
How do you like that Sam James cowl?
I had a tough time getting my Van's standard issue cowl to fit.
Mike Ice
RV-9
firewall forward
PostPosted: Mon Feb 25, 2008 7:23 am    Post subject: Firewall foreward cooling air needs Reply with quote
Mike,
The way I understand it is in order to get a decent heat exchange, the heater box metal is slightly thinner - coupled with the fact that it is a muffler internally means that it will get pretty hot. This also eliminates using preheated air as an option.
I really like the Sam James cowl. I am still installing the plenum - it's not fitting nearly as well as the cowl.....too wide in the front, too short in the back. I started with Vans baffle kit - but that doesn't account for the variances - I was able to adapt the inlet ramps to the plenum intakes though....but it took a bunch of work.
Ralph
aurbo(at)ak.net
PostPosted: Mon Feb 25, 2008 8:23 pm    Post subject: Firewall foreward cooling air needs Reply with quote
Ralph,
Hmm! Perhaps I am not quite understanding this but don't you want the heat
muffs to be hot. From what I have heard getting any heat into an RV (I don't
know what your building) is hard enough to do.
I am glad you like your decision with the James cowl and plenum. A friend
with an RV-9A went the same route as you and is very happy with the set up.
Not much activity on this message group. You might have better luck on Van's
Air Force web site, http://www.vansairforce.net/. There is always lots going
on that site, check out this link,
http://www.vansairforce.com/community/search.php?searchid=3368738,
Good luck, keep building,
Mike
Dale Ensing
PostPosted: Tue Feb 26, 2008 3:38 am    Post subject: Firewall foreward cooling air needs Reply with quote
FWIW if I am understanding correctly..... The heat muffs are really not
like a muffler internally. There are no baffles. I have two heat muffs in
tantum on my RV-6A to maximize heat which has worked very well now for three
years. I don't think using preheated air is a problem.
Dale Ensing
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
PostPosted: Tue Feb 26, 2008 4:36 am    Post subject: Firewall foreward cooling air needs Reply with quote
Dale,
I'm just going with what Larry Vetterman told me 'constant individual cooling air'. They may or may not have baffles - but now I'm gonna look.
Ralph
PostPosted: Tue Feb 26, 2008 4:40 am    Post subject: Firewall foreward cooling air needs Reply with quote
I actually do want them hot. I'm just going with what Larry Vetterman provided me - 'constant individual cooling air'.
If I don't get enough heat, I'll consider the SS Scrubbies or a wire wrap coil.
It's an older (small-tail) 6A.
I'll check out Doug's area.....
aurbo(at)ak.net
PostPosted: Tue Feb 26, 2008 6:25 am    Post subject: Firewall foreward cooling air needs Reply with quote
Ralph,
I agree with Dale. I just installed two of those Van's type heat muffs and
they did not have any internal baffles. The outlet air does have a plate in
it with a bunch of small holes punched in it. I suppose that is to slow the
air down a little so it will have a chance to get warm.
I have heard that it is best to install the muff with the inlet air the
farthest down on the pipe and the outlet air up. I guess because heated air
rises, Maybe??
I installed two power port outlets (cigarette lighters) in the airplane so
the wife and I can wear electrically heated vests. I want to be warm and I
have never been too impressed with aircraft heaters. Even in the summer it
gets cold in Alaska especially at altitude.
Mike
PostPosted: Tue Feb 26, 2008 7:16 am    Post subject: Firewall foreward cooling air needs Reply with quote
Mike,
Thanks for your response.
My heater/mufflers are made by Aircraft Exhaust Technologies for Larry Vetterman's systems. When they're not heating the cabin, the heated air flows out the valve dump. The requirement is that they always have to have air flowing over them and they can't be run in series. I've read that they do provide plenty of heat.
Sorry for the confusion - I think I will be OK with the setup.
Ralph
aurbo(at)ak.net
PostPosted: Wed Feb 27, 2008 7:05 am    Post subject: Firewall foreward cooling air needs Reply with quote
Ralph,
I took the time to look at Vetterman's web site. Damn fine product.
Build on.
Mike
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> LycomingEngines-List All times are GMT - 8 Hours
