Need two antennas for two radios??
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
donmorrisey
PostPosted: Thu Mar 13, 2008 8:04 am    Post subject: Need two antennas for two radios?? Reply with quote
Hello Listers,
I am at the spot in cabin construction that I need to finalize what I'm doing for antennas. I have two radios (Garmin & Becker) and a PMA 4000 audio panel all nicely wired up by Stark Avionics.
Do I need to install two antennas or one w/ a splitter?
Any recommendation on antenna. I have the cheapie homebuilder's special from Spruce, but am thinking maybe I should upgrade.
Thanks. Don...
www.donsbushcaddy.com
Don Morrisey's Skunkworks
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out. [quote][b]
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Don...
BushCaddy R120
http://www.donsbushcaddy.com
reichec
PostPosted: Thu Mar 13, 2008 3:23 pm    Post subject: Need two antennas for two radios?? Reply with quote
Install 1 CI 121 on the upper fuselage, and a CI 122 on the bottom. Feed them with rg142 or rg400.
Float Flyr
PostPosted: Thu Mar 13, 2008 6:15 pm    Post subject: Need two antennas for two radios?? Reply with quote
The short answer is two antennas... Especially if there are two transmitters.
Noel
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Don Morrisey
Sent: Thursday, March 13, 2008 1:28 PM
To: avionics-list(at)matronics.com
Subject: Need two antennas for two radios??
Hello Listers,
Thanks. Don...
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
rdfel
PostPosted: Sun Mar 16, 2008 6:58 pm    Post subject: Re: Need two antennas for two radios?? Reply with quote
You can use 1 antenna for 2 radios, contact Bob Archer of Archer Sport Antennas, he has a very nice switch box that is tied into the key line of each radio, effectively switching which radio transmits through the antenna. It's also setup to receive on both radios. BTW, it's about the price of an antenna, doesn't save any money, but clean-ups the airframe.
Part number SA-010
Check this link : http://home.hiwaay.net/~sbuc/tvrvbg/PRODS2.doc
Phone number : 310-316-8796
Good luck!!!!
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
