RV-8A Aileron Stops
japhillipsga(at)aol.com
PostPosted: Mon Mar 17, 2008 5:36 am    Post subject: RV-8A Aileron Stops Reply with quote
Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info for setting the swing limits for the ailerons. I see where the drawings shows where to put the stop, but I need to know how far up and down the aileron can travel. Who can help me out? Also, are we to put the stops on both ailerons? One to stop up and the other to stop down? Thanks, Bill of Georgia
DONKEYVET(at)aol.com
PostPosted: Mon Mar 17, 2008 8:03 am    Post subject: RV-8A Aileron Stops Reply with quote
Hey Bill,
Have you seen any planes out there with the plastic spacers in the aileron hinge used to limit the travel of the ailerons. Just did mine this way. Simple and elegant.
http://bowenaero.com/mt/2007/12/aileron-stops.html
better link
http://www.rv8.ch/article.php?story=20040924215600851
Dennis
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
sportypilot(at)stx.rr.com
PostPosted: Mon Mar 17, 2008 8:10 am    Post subject: RV-8A Aileron Stops Reply with quote
The manual shows up and down degree's
Of min and max travel and yes both use
Travel stops
Danny
Sent from cell
On Mar 17, 2008, at 8:31 AM, japhillipsga(at)aol.com (japhillipsga(at)aol.com) wrote:
[quote]Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info for setting the swing limits for the ailerons. I see where the drawings shows where to put the stop, but I need to know how far up and down the aileron can travel. Who can help me out? Also, are we to put the stops on both ailerons? One to stop up and the other to stop down? Thanks, Bill of Georgia
at6c(at)bellsouth.net
PostPosted: Mon Mar 17, 2008 10:50 am    Post subject: RV-8A Aileron Stops Reply with quote
The control throw specs are in Chapter 15 page 2. Up 25 to 32 deg, down 15 to 17 deg. Good luck.
George
<![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of japhillipsga(at)aol.com
Sent: Monday, March 17, 2008 8:32 AM
To: rv8-list(at)matronics.com
Subject: RV-8A Aileron Stops
PostPosted: Tue Mar 18, 2008 8:36 am    Post subject: RV-8A Aileron Stops Reply with quote
Dennis, it does seem to be a more eloquent way to employ a stop. How do you turn this stuff down to get the min/max degrees of travel? I don't have access to a lathe. Also, can I get some of this tube stuff from you (if you have extra)? Best regards, Bill
PostPosted: Tue Mar 18, 2008 8:46 am    Post subject: RV-8A Aileron Stops Reply with quote
Danny, thanks for the info. I finally found the chart in the Section 15. Best regards, Bill
PostPosted: Tue Mar 18, 2008 9:21 am    Post subject: RV-8A Aileron Stops Reply with quote
George, thanks for the info. My dear Wife found the chart last night for me and again I had to suffer under her wagging tongue of humiliation and jest. I hate it when she finds something I looked for for days!
Best regards, Bill
PostPosted: Thu Mar 20, 2008 6:00 am    Post subject: RV-8A Aileron Stops Reply with quote
Bill,
Sorry for the late reply. The plastic we bought had a 1/2 inch outter diameter and that seems to work great for the aileron travel limits! I might have some left over but I'm leaving town in a matter of minutes. Back Monday. Do you still have my phone number. We could talk about sending you some then.
Dennis
Create a Home Theater Like the Pros. Watch the video on AOL Home.
PostPosted: Thu Mar 20, 2008 8:03 am    Post subject: RV-8A Aileron Stops Reply with quote
Dennis, yes I still have your number. I'll call you Monday, Thanks, Bill
