Questions on avionics
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
Rv9APlane
PostPosted: Sun Apr 13, 2008 4:53 pm    Post subject: Questions on avionics Reply with quote
Hi all,
I have a couple of basic questions I don't understand well:
1. What does it mean to "cage" an attitude indicator? I've never flown a plane that has had this option but I see it on some I'm considering for my homebuilt.
2. I want a light IFR panel and have read some things about Mode S transponders. Is there any advantage to having one over a Mode C other than the TIS capability?
3. Is purchasing a separate encoder necessary? I was planning on putting a Blue Mountain EFIS One in my plane (please no negative comments as I'm already committed), a Garmin 430W with a GI-106A CDI, and a Garmin 327 transponder (pending the answer to number 2 above) in my plane. I see some avionics vendors packaging in a separate encoder but don't really understand why.
Thanks for your help
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Bruce Peters
RV9A, Fuselage
Bakersfield, CA
douglist(at)macnauchtan.c
PostPosted: Sun Apr 13, 2008 6:30 pm    Post subject: Questions on avionics Reply with quote
Gyros come in gimbals that allow the rotor to stay in a plane (That's a term of geometry here.) while the airplane moves around it. When you cage a gyro you clamp the bearings in the gimbals so that the rotating wheel is held so that its axis turns with the airplane. You do it when you set a directional gyro and then release it. Older attitude indicators could be made to lie by exceeding the limits of their gimbals and the two axes would line up with each other and the gyro would lock up and "tumble". Caging it would keep it from tumbling but would also make it unusable for flight.
Mode ADS-B is coming. It's a political point but I'd not waste cash on mode -S when ADS-B may be required before you get much out of S.
You need a barometric input for any of the transponder modes. GPS altitude won't cut it. So external or internal it has to be a pressure measuring device connected with a tube to the static system.
--> From the U S of A, the only socialist country that refuses to admit it. <--
Rv9APlane
PostPosted: Sun Apr 13, 2008 6:46 pm    Post subject: Questions on avionics Reply with quote
Thanks Doug, I appreciate the help.
On Sun, Apr 13, 2008 at 7:24 PM, Doug McNutt <douglist(at)macnauchtan.com (douglist(at)macnauchtan.com)> wrote:
[quote]--> Avionics-List message posted by: Doug McNutt <douglist(at)macnauchtan.com (douglist(at)macnauchtan.com)>
--> Avionics-List message posted by: "Rv9APlane" <rv9aplane(at)gmail.com (rv9aplane(at)gmail.com)>
Bruce Peters
RV9A, Fuselage
Bakersfield, CA
rampil
PostPosted: Mon Apr 14, 2008 3:38 am    Post subject: Re: Questions on avionics Reply with quote
The encoder output from a Blue Mountain EFIS is a perfectly adequate
barometric encoder derived from its air data system.
As long as it passes biannual inspection like any other encoder, it is
legal and good to go. My old G3 encoder always passed inspection
Ira N224XS
Rv9APlane
PostPosted: Mon Apr 14, 2008 6:49 pm    Post subject: Questions on avionics Reply with quote
Thanks Ira, I appreciate the help!
Bruce
On Mon, Apr 14, 2008 at 4:38 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
[quote]--> Avionics-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=176685#176685
Bruce Peters
RV9A, Fuselage
Bakersfield, CA
bakerocb
PostPosted: Tue Apr 15, 2008 4:42 am    Post subject: Questions on avionics Reply with quote
4/15/2008
Hello Bruce, You wrote:
"1. What does it mean to "cage" an attitude indicator?"
Some attitude indicators have a mechanical means to lock the gyro gimbals so
that the gyro gimbals are held rigidly to the instrument case. This can
serve two functions:
A) It can save wear and tear on the gyro if you are going to do some
aerobatic manuevering and don't want the gyro to be moving around
extensively as it tries to always show the proper aircraft attitude.
B) If the gyro has tumbled and one wants to erect it again to a proper
attitude one can put the airplane in a level attitude, cage and then uncage
the gyro, and it will then start indicating properly a level attitude from
that new starting point.
"3. Is purchasing a separate encoder necessary?.....I see some avionics
vendors packaging
in a separate encoder but don't really understand why."
They are doing this because the altitude encoder in almost all of the EFIS
being sold to the amateur built community are not TSO'd and therefore do not
comply with FAR Sec 91.217 copied here:
"91.217: Data correspondence between automatically reported pressure
altitude data and the pilot's altitude reference.
No person may operate any automatic pressure altitude reporting equipment
associated with a radar beacon transponder-
(a) When deactivation of that equipment is directed by ATC;
(b) Unless, as installed, that equipment was tested and calibrated to
transmit altitude data corresponding within 125 feet (on a 95 percent
probability basis) of the indicated or calibrated datum of the altimeter
normally used to maintain flight altitude, with that altimeter referenced to
29.92 inches of mercury for altitudes from sea level to the maximum
operating altitude of the aircraft; or
(c) Unless the altimeters and digitizers in that equipment meet the
standards of TSO-C10b and TSO-C88, respectively."
So you can see that an altitude encoder in use must meet either be TSO'd or
comply with subparagraph (b) above.
Some people think that the encoder, altimeter, and transponder checks
required every two years by FAR Sections 91.411 and 91.413 meet the
requirements of subparagraph (b) above, but that is not the present position
of FAA HQ. They prescribe a more elaborate, almost impossible to accomplish
test.
So one solution to the problem created by having an EFIS with a non TSO'd
altitude encoder installed in your airplane is to install and use a separate
TSO'd altitude encoder.
If you want to read more on this subject go to the Matronic aeroelectric
list archive and search for 91.217.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PS: Some EFIS manufacturers will claim that their altitude encoder "meets
TSO standards". Note that a claim of "meeting TSO standards" and being
actually TSO'd are not the same thing. Ironically some of these non TSO'd
altitude encoders are actually superior in performance and technology than
the standards required by the TSO. The EFIS manufacturers have chosen not to
obtain actual TSO approval for their altitude encoders because of the
expense and bureaucratic burden involved.
Time: 05:57:43 PM PST US
Subject: Questions on avionics
Hi all,
plane
homebuilt.
transponders.
capability?
a Blue
committed),
packaging
Bruce Peters
RV9A, Fuselage
Bakersfield, CA
bakerocb
PostPosted: Thu Apr 17, 2008 5:55 pm    Post subject: Questions on avionics Reply with quote
4/17/2008
Hello Ira,
1) You wrote: "There is no requirement for TSO in owner built aircraft."**
2) FAR SEC 91.217 Says:
"Data correspondence between automatically reported pressure
3) Please explain, with specific valid reference, why the phrase "No person
may ..." seen above would not apply to a person flying an amateur built
experimental aircraft.
4) You are correct that there are alternatives to using TSO'd equipment,
when such equipment is specifically required by a regulation, provided that
you can prove to the FAA's satisfaction that your alternative equipment is
acceptable to the FAA. Here is how you go about doing that:
FAR Sec. 21.609 "Approval for deviation.
(a) Each manufacturer who requests approval to deviate from any performance
standard of a TSO shall show that the standards from which a deviation is
requested are compensated for by factors or design features providing an
equivalent level of safety.
(b) The request for approval to deviate, together with all pertinent data,
must be submitted to the Manager of the Aircraft Certification Office for
the geographic area in which the manufacturer is located. If the article is
manufactured in another country, the request for approval to deviate,
together with all pertinent data, must be submitted through the civil
aviation authority in that country to the FAA."
Obtaining an approval for deviation is not a trivial task and none of the
manufacturers of non TSO'd altitude encoders contained in their EFIS units
have done so to my knowledge.
**PS: This statement is also not correct when it comes to the ELT installed,
if one is required by FAR Sec 91.207, in an amateur built experimental
aircraft.
Time: 04:30:41 AM PST US
Subject: Re: Questions on avionics
Re: TSO and altimetry sources
There is no requirement for TSO in owner built aircraft. As I said
previously, there is only a performance requirement.
Part 23 is a separate issue.
Ira N224XS
bakerocb
PostPosted: Sat Apr 19, 2008 4:15 am    Post subject: Questions on avionics Reply with quote
4/19/2008
Hello Ira, You wrote: "........I was referring to encoding altimeters when I
said there
was no requirement for TSO."
If that encoding altimeter is the altitude encoder that is feeding the
transponder required by FAR Sec 91.215 then it must comply with either
91.217 (b) or (c). That is what this thread has been about.
See my response to Mike, copied below, for more information.
'OC'
4/18/2008
Hello Mike, Thanks for your three emails. You wrote:
1) "....you are looking to comply with the standard of the TSO without a
formal
proof."
A) I invite you to look at "Subpart O -- TSO Authorizations" of FAR Part 21.
You can access it here:
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=9dad7a792e03c09e14fc110ded0921cb&rgn=div6&view=text&node=14:1.0.1.3.9.15&idno=14
B) Then I invite you to look at TSO-C10b. You can access it here:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgTSO.nsf/0/072c91c58fdc6ce686256da4005f4d1b/$FILE/C10b.pdf
C) Then I invite you to look at TSO-C88b. You can access it here:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgTSO.nsf/0/625ebf9767dac15e8625727c006e10df/$FILE/TSO-C88b.pdf
D) Now I invite you (and here is the gotcha) to procure and look at all the
technical references contained in those TSO's. The TSO's themselves are just
sort of shell documents, pointers if you will. All the real technical guts
and standards that must be complied with are found in the references.
E) Now I ask you to picture the average homebuilder satisfying someone that
he is complying with the standards of the relevant TSO's without formal
proof.
2) "It says that the 'encoder' must meet the TSO standards. It doesn't say
that it must be TSO'd. That is a subtle legal difference."
I accept your "subtle legal difference". After you have gone through steps A
through D above I ask you to picture the average homebuilder satisfying
someone that his non TSO'd altitude encoder is meeting the standards of the
relevant TSO's .
3) "So answer me this: If you the builder /manufacturer determines that
your testing puts the encoder in compliances with the TSO standards......."
Again I ask you to picture the average amateur builder determining that his
testing puts the encoder in compliance with the TSO standards -- not some of
the standards, not just the performance standards, but the all of the TSO
standards. The reason that the EFIS manufacturers have not done this very
thing is because of the significant cost and bureacratic burden involved.
4) "...and you test the unit IAW 43.13 and it passes ......"
A) (I am not sure why you referenced 43.13. It does not appear to be
relevant here. Perhaps you meant FAR Sec 91.413. I will assume so.)
First off I, the amateur builder, am not permitted to perform the tests
required by 91.413 -- see sub paragraph (c) of 91.413.
B) "......what would be the ramifications?"
Second, assuming the tests required by 91.413 were properly performed by a
willing qualified person / entity, the automatic pressure altitude reporting
equipment containing the non TSO'd altitude encoder passed the tests, and
the test results were properly documented there probably would be no adverse
ramifications. But consider this:
B-1) Suppose a willing qualified person / entity is not readily available to
perform the 91.413 required tests because the non TSO'd altitude encoder is
not in compliance with 91.217? What are the ramifications then? Probably no
big deal, go find someone or some place that will perform the tests.
B-2) Suppose that there is a mid air collision between an amateur built
experimental aircraft and an airline aircraft with major loss of life. And
further suppose that the equipment in the amateur built experimental
aircraft had absolutely nothing to do with causing the accident, but the
media learns that the amateur built experimenal aircraft was not in
compliance with some Federal Aviation Regulation (91.217) . What are the
ramifications then?
5) "I don't see a violation of the rule as written."
I am not sure which rule you are referring to. If you are referring to
91.217 there are two choices:
A) Comply with subparagraph (c); ie have equipment that is TSO'd, or
B) Comply with the tests described in subparagraph (b). I think that the
tests required by 91.411 and 91.413 should be considered to meet the
requirements of 91.217 (b). Unfortunately, to date the FAA HQ does not agree
with me and they seem to have a little more authority than I do.
6) "Also their is no enforcement mechanism in place to even determine
whether your in compliance or not."
True enough. I think the FAA is too busy measuring the spacing between
lacings on wire bundles in the wheel wells of airliners to make very many
ramp checks on the avionics installed in amateur built experimental
aircraft, but see the ramifications comments above and make an informed
decision.
7) "You as the aircraft certifying authority as the builder......"
The Special Airworthiness Certificate in the Experimental Category for the
purpose of Operating Amateur Built Aircraft is signed and issued by an FAA
Representative who has been delegated that authority by the FAA
Administrator. The FAA Administrator is the certifying authority, not the
amateur builder.
Cool "You ........ as the builder determine suitability as it pertains to the
regulations and no one else"
Try telling that to the FAA employee or DAR who comes to inspect your
amateur built experimental aircraft for its initial airworthiness
inspection. He will set you straight very quickly on who will make the
decisions regarding the suitability of your aircraft as it pertains to
regulations.
9) "Short of them scouring the wreckage for TSO tags they would have to make
an assumption."
I hope that it would never come to that, but the tenacity, search for
details, and the ill will of lawyers and journalists when they smell blood
and money should not be ignored. All I am seeking to do is to have people
make informed decisions -- I provide the information, they make the
decisions.
Time: 08:28:34 PM PST US
Subject: RE: AeroElectric-List: Questions on avionics
I would argue that you are not looking for a deviation to the TSO you
are looking to comply with the standard of the TSO without a formal
proof.
Mike
Time: 08:34:11 PM PST US
Read the regulation. It says that the 'encoder' must meet the TSO
standards. It doesn't say that it must be TSO'd. That is a subtle
legal difference.
Mike
douglas.dodson(at)pobox.c
PostPosted: Sat Apr 19, 2008 8:06 am    Post subject: Questions on avionics Reply with quote
This discussion is symptomatic of what is driving light aircraft GA into
oblivion. If I get my transponder static check done and it passes, then
the system works today. I suppose it could break tomorrow, but so could
one that "legally" meets the TSO. At least I can afford to fix mine
since the engineers didn't have to pay any lawyers.
- Doug
bakerocb
PostPosted: Sun Apr 20, 2008 4:55 am    Post subject: Questions on avionics Reply with quote
4/20/2008
1) "This is just the performance test."
I assume that you mean the testing required every two years by FAR Sec's
91.411 and 91.413 as appropriate.
I apologize for not having made the situation clearer to you. I also wanted
the testing required by 91.411 / 91.413 to sufficiently meet the
requirements of 91.217 (b) so that one could operate with an EFIS that
contained the only atitude encoder in the airplane and that altitude encoder
would be non TSO'd. So I wrote to FAA HQ asking that question. Here is an
exact quote of their response:
"Your letter posed the following questions:
1. If an amateur built experimental aircraft has an installed TSO'd ATC
transponder as required by Title 14 Code of Federal Regulations (14 CFR)
section 91.215, but a non-TSO'd altitude encoder and the installation has
passed the test and inspection requirements of 14 CFR sections 91.411 and
91.413 within the preceding 24 calendar months, does the installation meet
the requirements of 14 CFR section 91.217(b), and therefore make that
installation acceptable for IFR operations?
2. If the answer to question one is No, can you please tell me
why?
The answer to question one is "No." The testing required to show the
transmitted altitude data corresponds within 125 feet (on a 95 percent
probability basis) is more rigorous than the requirements referenced in 14
CFR sections 91.411, 91.413, and 14 CFR, part 43 appendices E and F. The
tests required by 14 CFR part 43 appendix E(c) measure the automatic
pressure altitude at a sufficient number of test points to ensure the
altitude reporting equipment performs its intended function.
Title 14 CFR section 91.217 paragraphs (b) and (c), state that pressure
altitude reporting equipment must be tested and calibrated to transmit
altitude data correspondence within stated specifications; or, the
altimeters and digitizers must meet the standards in TSO-C10B and TSO-C88,
respectively.
Should the owner/operator elect to exhibit compliance with tests and
calibration provided in 14 CFR section 91.217(b), a test method would need
to be developed that ensures the transmitted data corresponds within 125
feet of the indicated altitudes from sea level to the maximum operating
on a 95 percent probability basis. This testing also needs to ensure the
performance characteristics of the equipment are not impacted when
subjected to environmental conditions (voltage fluctuations temperature,
vibration, etc.) which may be encountered in airborne operations.
Completed tests and calibration results should be maintained in the
aircraft records.
Thank you for your interest in aviation safety."
So you can see that FAA HQ does not agree with our wishes. Further you can
see that an amateur builder attempting to comply with the FAA HQ version of
the testing requirements of 91.217 (b) in order to avoid having a TSO'd
altitude encoder installed in his airplane would have a very difficult /
impossible time doing so.
2) "It says nothing about TSO."
That is correct. The TSO part is found in 91.217 (c). So the person
mentioned in the beginning of 91.217 is given two choices -- he can comply
with either 91.217 (b) or (c).
3) "Part 21 and 23 do not apply to owner built aircraft with special
airworthiness certificates."
Basically true, but not specifically relevant to this discussion unless the
builder would try to use a non TSO'd altitude encoder by requesting approval
to deviate from TSO C-88b and its references in accordance with the
procedures of FAR Sec 21.609 -- not a trivial task.
Please let me know if I have not adequately described the situation.
Time: 07:01:52 AM PST US
Subject: AeroElectric-List: Re: Questions on avionics
Again, back to 91.217 (b):
This is just the performance test. It says nothing about TSO.
Ira N224XS
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
