		Terry Phillips
  Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
				 Posted: Sat Apr 26, 2008 9:05 pm    Post subject: Zenith Builders Analysis Group |
				At 02:24 PM 4/25/2008 -0500, John Bolding wrote:
   	  | Quote: | 	 		  Jeff,
  No deviation from my feeble point of view.
  Progress is slow on the engineering front, I'm gonna call Thurston and see if he's interested in the project in case the academic doesn't pan out. He may want something useful to do in his spare time.
  Ya'll choose up a point man so if somebody says they are ready to do it there won't be any fumbling around. I think it needs to be a 601 guy in the middle of this as there might be some back and forth.
  Progress is indeed slow. However, there is some that I  can report. Apparently it is finals time at Embry-Riddle, so the profs are pretty busy. I have sent them links to the Yuba City photos, as well as, scans of several of my wing drawings. We have tentatively arranged a phone call on Thursday, May 1 to discuss the engineering evaluation of the 601XL wing. In preparation for that call, I have drafted a statement of work that I will append to this message. I would invite comments, suggestions, flames, whatever. I'll need a revised version before the phone call.
  I spoke with one of the 601XL builders who I was hoping could provide a second signature on the bank account to provide a measure of fiscal control for the project. He told me that he would not take that role because he was concerned about potential liability. And, he more or less told me that I was crazy if I took an active role. I guess I'm crazy. I think someone has to take some initiative. It's either that, or walk away from a year of work and a $16,000 investment. Because I do not have the confidence I need in the aircraft at this time. However, his point is well taken, and I'm considering the following steps to limit liability exposure:  - Distribute the engineering report only to those "members" who have  supported the analysis financially.
 - Require each "member" to sign a release and hold harmless form that would be shamelessly plagiarized from the forms I had to sign for ZAC and JabiruUSA.
 - Initiate work on the analysis only after enough funding has been received to fund the complete statement of work.
 - If sufficient funds are not received within 4 weeks of the initial request for funding, then all checks will be returned using a SASE provided by each "member," and the analysis will not be done.
  Again, I invite your comments, flames, whatever, on the above. It's possible imposing the above conditions would decrease support so that the analysis could not be made. If so, I would be happy to relinquish my role to anyone who has a better  idea to make the analysis happen. Let me know if you are interested.
  Draft Statement of Work:
  Statement of Work for Zenith CH601XL Independent Engineering Analysis
  Rev. 0
  April 26, 2008
  GOAL:  The goal of this analysis is to analyze the wing design of the CH601XL:
   -  To attempt to determine whether the structure, as designed, has adequate strength to meet the published design loads of +6G and -3G.
    - Assuming that the analysis shows that the structure, as designed probably has adequate strength, then
    - Evaluate the susceptibility of the flaps and ailerons to flutter. If the analysis shows that flutter is a possible occurrence when a  CH601XL is flown within the design envelope, then evaluate possible modifications to minimize or eliminate the flutter.
 - Consider the effect of design options on the ability of the wing to meet design standards:
 - Hinged vs. skin flex hinge aileron attachment.
 - Aileron trim tab option.
 - Wing locker option.
 - Landing light option.
 - Thirty gallon vs. 24 gallon fuel tanks.
    - Consider, to the extent possible given time and budget constraints, the effect of typicalbuilder mistakes, e.g.,
 - Wrong size or kind of rivets used at high stress location.
 - Missing, loose, or wrong sized bolts.
 - Mis-placed or wrong sized openings, e.g., the hole for the aileron control rod, holes in ribs for wiring, fuel lines, pitot lines, etc.
 - Two or three piece nose skin
     The first task will be to Review the information available about the accidents which have occurred that may have involved in-flight breakup of the aircraft structure. The purpose of this review is to discover information that might guide the analysis of the wing.
  At the completion of the investigation, the engineer will submit a written report covering the results and recommendations, if any, for changes to the aircraft design to reduce the possibility of in-flight breakup.
  Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
  601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings
  http://www.mykitlog.com/N47TP/     [quote][b]
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
				 Posted: Sat Apr 26, 2008 10:57 pm    Post subject: Zenith Builders Analysis Group |
				My comments:
 - I am not a lawyer. Although I can see some REMOTE possibility of the engineer doing the analysis incurring some liability it is hard to see how those paying him would. And any engineer worth his salt has been designing real-world projects and already addressed the liability issue.
 - I think the analysis should be informed by the load testing done to date by Zenith’s outside testing engineers. If at all possible the formal reports from those tests should be obtained from  Zenith (possibly directly by the contracted engineer)
 - If possible the engineer should be able to ask Zenith (preferably Chris) questions during his investigation. Otherwise it is very likely that he will finish his report with a conclusion of X and Zenith will come back and say “but you didn’t consider Y”. Some kind of conversation during the investigation would go a long way to ensure a useful outcome.
 - I assume that when the hypothetical engineer hears about the events motivating this project he will have his own ideas about what would make sense in the statement of work. He (or she) has done this kind of thing before, we have not. Your penultimate paragraph below basically says this.
 - I suspect the statement of work will have to be greatly cut back to make this project affordable. The question is how limited can the project be and still produce a useful result.
 - You might want to point whoever does the work to the Zenith Construction Standards document too.
 We could just wait until Sabrina has her degree and exploit her motivation. But I don’t want to wait 2 years until she graduates from MIT. J
 -- Craig
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Terry Phillips
  Sent: Saturday, April 26, 2008 10:50 PM
  Subject: Zenith Builders Analysis Group
 Jeff,
  Rev. 0
  April 26, 2008
  GOAL:  The goal of this analysis is to analyze the wing design of the CH601XL:    -  To attempt to determine whether the      structure, as designed, has adequate strength to meet the published design      loads of +6G and -3G.
 Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
  http://www.mykitlog.com/N47TP/    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith-List  | 	  0123456789
		Iberplanes
  Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
				 Posted: Sun Apr 27, 2008 2:01 am    Post subject: Zenith Builders Analysis Group |
				I think engine choise vs vibrations should be included.  E.g.. Rotax 912 and Jab3300.
  Alberto Martin
 Iberplanes IGL
 http://www.iberplanes.es
 Igualada -  Barcelona - Espaņa
  [quote]   ---
  _________________ Alberto Martin
601 XL - Jabiru 3300
Igualada - Barcelona - Spain |
		planecrazydld(at)yahoo.co Guest
				 Posted: Sun Apr 27, 2008 3:45 am    Post subject: Zenith Builders Analysis Group |
 Terry;
 Why +6 -3 G's? My current edition plans still show +/-6 G's.
 Terry Phillips <ttp44(at)rkymtn.net> wrote:[quote]   At 02:24 PM 4/25/2008 -0500, John Bolding wrote:
   	  | Quote: | 	 		  Jeff,
  Rev. 0
  April 26, 2008
     The first task will be to Review the information available about the accidents which have occurred that may have involved in-flight breakup of the aircraft structure. The purpose of this review is to discover information that might guide the        Be a better friend, newshound, and  [quote][b]
		purplemoon99(at)bellsouth Guest
				 Posted: Sun Apr 27, 2008 6:02 am    Post subject: Zenith Builders Analysis Group |
				Terry,I sent the email to Matt,no reply as of yet,  just read your post, and I 'am with this effort 100%,  like I said before  my plane is staying on the ground untill this matter is solved. keep me in the  loop....Joe N101HD 601XL/RAM
  [quote]   ---
		sdthatcher
  Joined: 13 Mar 2008 Posts: 91 Location: Port Saint Lucie
				 Posted: Sun Apr 27, 2008 7:03 am    Post subject: Zenith Builders Analysis Group |
				Thanks Terry for taking an active part in this  endeavor.
  Here are some additional items that I feel need to  be addressed as well.
     - Smoking rivets (or elongated rivet holes in wing    areas)
 - Varying amounts of fuel (someone mentioned that a    flutter was observed in a different aircraft when fuel was 1/3    capacity)
 - Missing nylon flap stop (inducing vibrations at    cruise)
   Thanks again for your efforts.
  Scott Thatcher, Palm Beach Gardens, FL
 601XL  with Corvair, Registered as E-LSA
 N601EL, http://placestofly.com, EAA203
  _________________ Scott Thatcher, Port Saint Lucie, FL
N601EL, EAA203 140 hours and not flying currently. |
		lwhitlow
  Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
				 Posted: Sun Apr 27, 2008 8:42 am    Post subject: Re: Zenith Builders Analysis Group |
				Terry and others who want an outside engineering analysis.
 I do understand your desire to be confident in the design and safety of the 601XL. Like you I have a $17500 kit that I want to be able to fly safely.
 But if you proceed with the analysis under the terms you have stated below, You will destroy not only your own investment of both time and money but you will destroy everyone else's investments in their aircraft as  well, NO MATTER WHAT THE ENGINEERING REPORT HAS TO SAY!!
 Curious?? I'll explain.
 If the analysis is done and a completed report exists then....
 If the results of the report are only seen by the "contributors" A giant unanswered question hangs over the aircraft, Is it OK??? Has a problem been found? Are there modifications suggested??  This will weaken the "airplane shopping publics" opinion of the aircraft, and perhaps be enough to make them choose another aircraft with "less of an unknown factor". Even if the report says every things A-OK, the very fact that its a secret, will deter buyers. If this choice occurs enough times then Zenith ceases production and support of the 601XL or perhaps ceases business all together. I'm sure we can all agree that this would not be a desirable outcome.
 Also a engineering report known only to some of the fleet of 601XL devalues them all. Questions will arise? Do you know about the report?  Have you made modifications based on the report? Once again confusion and unknowns take over and we all loose.
 More importantly  Lets say the report reveals something that should be addressed, and you get your secret copy. Are you, ( a builder, a pilot, an aviation enthusiast) actually going to let another pilot or builder fly a machine that you know has a problem and NOT TELL HIM OR HER ABOUT IT!!!  That's  not what the sport aviation community should be all about. Could you live with yourself knowing you could have prevented a tragedy but did nothing because the other person didn't contribute to the funding of this witch hunt.  By the way what if some people contribute less than others to the funding of this report???  Are you only going to give them part of the data? Maybe the higher dollar contributors get the data first and its held from the lower dollar contributors for a period of time.
 And of course if the report says "everything is fine"  Now What?  Its a secret, so all of the bad things listed above still happen, and the shrill voices calling for a redesign or "beef up" or whatever continue un-abated. AND WE ALL STILL LOOSE.
 The sport aviation community is about helping yourself and others fly enjoyably and safely. A secret report will do none of that and quite possibly be the beginning of the end of our hobby and pastime as we know it.  I hope than my son will be able to learn to fly and to build his own airplane someday. This has all the earmarks of seriously damaging something that I dearly love to do.
 Any crash or problem with a amateur built experimental aircraft affects us all. If we don't take good care and be as responsible as we possibly can within the rules currently in place,  then the not so interested government WILL step in and make things harder for all of us.
 I seen posts recently with all sorts of speculation, guesses, critical observations, and truly useful thoughts and suggestions, I think the discussion is valid and useful as long as it is the open exchange of ideas and working towards a common goal of a safe and fun airplane
 But, I implore all of you to not give into fear and hysteria while we search for a cause or problem. Statements like "As far as Yuba City, I'm almost willing to say case closed." have no place. We only know what we see in one set of pictures and what limited reports that have been released by the FAA. Analyzing such a limited data set takes time. The FAA has not stated a cause, the designer of the aircraft has not sated a cause. The manufacturer of the kit has not stated a cause, yet some people on this very forum want to put themselves above all of those knowledgeable and qualified people and say that there is a problem because they have managed to scrape together $18000 and buy a kit. It almost makes the statement, "are you an engineer??  No but I stayed in a Holiday Inn Express last night" seem reasonable.
 I would rather take contributions up to send Sabrina to the finest aviation and engineering schools in the world. Its people like her we need to be encouraging if we want to be able to pursue our hobby and to pass on the joy of flight to generations to come. We need younger people to be excited by piloting you own aircraft, and to be able to afford to do it. Look around you own EAA Chapters. How many up and comers do you have attending?
 FUD   Fear Uncertainty Doubt. These are not the characteristics you look for in a pilot. Seems to me we need to address this before we move on to metallurgy and tensile strength.
 Larry Whitlow
 Valparaiso IN
 601XL Builder
 Pilot since Age 15 Solo'ed on my 16th birthday Dad had to drive me to the Airport, because I couldn't get my drivers license for another month
  	  | Quote: | 	 		   ="Terry Phillips"]At 02:24 PM 4/25/2008 -0500,
 >>EDIT<<
  Rev. 0
  April 26, 2008
  Terry Phillips
 [/quote}
		Terry Phillips
				 Posted: Sun Apr 27, 2008 11:07 am    Post subject: Zenith Builders Analysis Group |
				Larry
  Thank you for your thoughtful reply. I appreciate your thoughts. They deserve a reply, so I will attempt one. For convenience, I will intersperse my replies within your comment below
  Terry
  At 09:43 AM 4/27/2008 -0700, you wrote:
   	  | Quote: | 	 		  Terry and others who want an outside engineering analysis.
  But if you proceed with the analysis under the terms you have stated below, You will destroy not only your own investment of both time and money but you will destroy everyone else's investments in their aircraft as  well, NO MATTER WHAT THE ENGINEERING REPORT HAS TO SAY!! |
  I may be unusual, but I do not look at my 601XL as an investment. I plan to fly it for as long as I am able to fly safely; eventually, my A/C will be part of my estate, and my heirs can do with it what they please. I recognize that, in the future, my personal circumstances may change and I may wish to recover my investment in the A/C. I guess I'll have to cross that bridge, if and when, I come to it.
   	  | Quote: | 	 		  Curious?? I'll explain.
  If the results of the report are only seen by the "contributors" A giant unanswered question hangs over the aircraft, Is it OK??? Has a problem been found? Are there modifications suggested??  This will weaken the "airplane shopping publics" opinion of the aircraft, and perhaps be enough to make them choose another aircraft with "less of an unknown factor". Even if the report says every things A-OK, the very fact that its a secret, will deter buyers. If this choice occurs enough times then Zenith ceases production and support of the 601XL or perhaps ceases business all together. I'm sure we can all agree that this would not be a desirable outcome. |
  Distributing the report only to contributors is a selfish attempt on my part to contain any potential liability for trying to get this analysis done. To my knowledge, only the US Government can define "secret" information in the USA. For most of my career I had a DOE Q-Clearance, and at times also a DOD Top Secret Clearance. For many years I was an ADC, an authorized derivative classifier. Even as an  ADC, I was only allowed to classify information subject to specific, written classification guidance issued by someone, at a higher level. Someone who really had the authority to determine what information could be classified. So no, the report will not be "secret." However, by issuing copies of the report only to members  who have contributed to the project and signed my cobbled up release and hold harmless agreement, I hope that I can deter any builder (or worse, their heirs) from suing  me because their lawyer has convinced them that they have a grievance. What the "members" of the group do with their copy of the report is up to them. But rest assured, they will not be subject  to criminal  prosecution--as I would be if today I disclosed US Government "secret" information. Perhaps I am overly paranoid. But I would like to preserve my meagre estate for my heirs and not spend it on legal expenses. Larry, you could personally resolve the "secret" issue by contributing to the analysis, and then posting your copy of the report on the Zenith-List. I'm just asking that you take that responsibility; don't condemn me for not doing it. It is a sad commentary on the state of our society that one must be concerned  about the threat of litigation. But the threat is real. In fact, I have read at least one post on the Zenith-List that suggested that ZAC should be concerned. Good grief!
   	  | Quote: | 	 		  Also a engineering report known only to some of the fleet of 601XL devalues them all. Questions will arise? Do you know about the report?  Have you made modifications based on the report? Once again confusion and unknowns take over and we all loose.
  More importantly  Lets say the report reveals something that should be addressed, and you get your secret copy. Are you, ( a builder, a pilot, an aviation enthusiast) actually going to let another pilot or builder fly a machine that you know has a problem and NOT TELL HIM OR HER ABOUT IT!!!  That's  not what the sport aviation community should be all about. Could you live with yourself knowing you could have prevented a tragedy but did nothing because the other person didn't contribute to the funding of this witch hunt.  By the way what if some people contribute less than others to the funding of this report???  Are you only going to give them part of the data? Maybe the higher dollar contributors get the data first and its held from the lower dollar contributors for a period of time. |
  Membership in the group would not be restricted in any way. Chris Heinz is welcome and encouraged to join. My expectation is that the analysis will  find  that the XL  design is essentially sound. In the event that a significant flaw is detected, I would personally send a copy of the report to the NTSB and let them take responsibility for further distribution of that finding. In any event, I cannot and will not take responsibility to "tell him or her about it." Particularly since, I do not know just whom "him or her" might  be.
   	  | Quote: | 	 		  | And of course if the report says "everything is fine"  Now What?  Its a secret, so all of the bad things listed above still happen, and the shrill voices calling for a redesign or "beef up" or whatever continue un-abated. AND WE ALL STILL LOOSE. |
  I fail to see how the engineering analysis of the 601XL design will increase the FUD that you refer to. I expectation is that the analysis will reduce FUD.
   	  | Quote: | 	 		  The sport aviation community is about helping yourself and others fly enjoyably and safely. A secret report will do none of that and quite possibly be the beginning of the end of our hobby and pastime as we know it.  I hope than my son will be able to learn to fly and to build his own airplane someday. This has all the earmarks of seriously damaging something that I dearly love to do.
  But, I implore all of you to not give into fear and hysteria while we search for a cause or problem. Statements like "As far as Yuba City, I'm almost willing to say case closed." have no place. We only know what we see in one set of pictures and what limited reports that have been released by the FAA. Analyzing such a limited data set takes time. The FAA has not stated a cause, the designer of the aircraft has not sated a cause. The manufacturer of the kit has not stated a cause, yet some people on this very forum want to put themselves above all of those knowledgeable and qualified people and say that there is a problem because they have managed to scrape together $18000 and buy a kit. It almost makes the statement, "are you an engineer??  No but I stayed in a Holiday Inn Express last night" seem reasonable. |
  I absolutely agree that knowledgeable analysis of the situation is required. The only question is how to get that done.
   	  | Quote: | 	 		  I would rather take contributions up to send Sabrina to the finest aviation and engineering schools in the world. Its people like her we need to be encouraging if we want to be able to pursue our hobby and to pass on the joy of flight to generations to come. We need younger people to be excited by piloting you own aircraft, and to be able to afford to do it. Look around you own EAA Chapters. How many up and comers do you have attending?
  FUD   Fear Uncertainty Doubt. These are not the characteristics you look for in a pilot. Seems to me we need to address this before we move on to metallurgy and tensile strength. |
  Again, I suggest that the whole purpose of an independent analysis is to address Fear, Uncertainty, and Doubt. There may be better ways to address FUD, but  I do not believe that a good way is to pretend that it is not there. I am open to your suggestions for positive steps to reduce this FUD.
   	  | Quote: | 	 		  Larry Whitlow
  Valparaiso IN
  601XL Builder
  Pilot since Age 15 Solo'ed on my 16th birthday Dad had to drive me to the Airport, because I couldn't get my drivers license for another month |
  Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
				 Posted: Sun Apr 27, 2008 11:26 am    Post subject: Zenith Builders Analysis Group |
				I’m afraid that if you are trying to devise a strategy to minimize legal liability then you really need to get a lawyer involved. The strategy may only provide the illusion of some level of protection.
 IMHO the plan should just not worry about liability. Those who are concerned should just not join the group. True, this might greatly reduce the size of the group but so might the confidentiality clause.
 -- Craig, still building, still planning to fly my XL.
  Sent: Sunday, April 27, 2008 12:52 PM
  Subject: Re: Re: Zenith Builders Analysis Group
 Larry
  Terry
 Larry Whitlow
  Valparaiso IN
  601XL Builder
 Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
		lwhitlow
				 Posted: Sun Apr 27, 2008 11:37 am    Post subject: Re: Zenith Builders Analysis Group |
				Terry
 I'm very happy you read my thoughts and took the time to give me yours.
 I know that a solution must be found, and I appreciate yours and the others efforts to solve this
 My big beef is the spread of information. I would be happy to contribute myself but only if we tell the world (so to speak).
 The down sides are still there even if we do tell everyone about the engineers findings.  The best outcome can only come from Zenith doing an exhaustive analysis along with Zenith having an outside engineer review and concur.
 I agree with Larry McFarland I think the root of the current crashes will lie with the manufacturer. and not a design issue.  But the reality is that only Zenith can put this issue to bed, not us
 Thanks for taking the time
 Larry Whitlow
  	  | Quote: | 	 		  ="Terry Phillips"]Larry
  Terry
  Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
		ashontz
				 Posted: Sun Apr 27, 2008 12:46 pm    Post subject: Re: Zenith Builders Analysis Group |
				Terry, along with checking for flap or aileron flutter, they should be checking for flutter of the entire wing too.
 [quote="Terry Phillips"]At 02:24 PM 4/25/2008 -0500, John Bolding wrote:
   	  | Quote: | 	 		  Jeff,
  Rev. 0
  April 26, 2008
  Terry Phillips
  ttp44~at~rkymtn.net
  Corvallis MT
		ashontz
				 Posted: Tue Apr 29, 2008 11:34 am    Post subject: Re: Zenith Builders Analysis Group |
				I posted this in the Unintended Consequenses thread, but I think it's worth noting here also just in  case no one here is reading that thread. If you haven't you might want to take a look at it.
 The more I think about this, the more I agree. Lawyers already ruined general avaition, no sense letting one buy another waterfront home in Boca Raton (and an original restored P-51 Mustang as a trophy for a 'job(?) well done') and in the process ruin homebuilding for everyone else. Too many lawyers in this country and not enough real producing workers like homebuildes themselves. As soon as I saw someone in the analysis group mention a lawyer, that's time to do a 180 on that noise. Drop the issue, shut up and build your plane or sell or scrap it if you don't want to build it. BUT DO NOT LET THE SPOILS OF GENUINE HARD WORK GO TO LAZY PARASITIC LAWYERS THAT ARE AFRAID OF A HAMMER AND COULDN'T SURVIVE 3 SECONDS IN A WORLD WITHOUT SOMEONE TO LEACH OFF OF.
		ihab.awad(at)gmail.com Guest
				 Posted: Tue Apr 29, 2008 12:18 pm    Post subject: Zenith Builders Analysis Group |
				On Tue, Apr 29, 2008 at 12:34 PM, ashontz <ashontz(at)nbme.org> wrote:
  	  | Quote: | 	 		   BUT DO NOT LET THE SPOILS OF GENUINE HARD WORK GO TO LAZY PARASITIC
 Wow. (a) Everyone loves their own lawyer and hates everyone else's.
 (b) In a civil society, this is indeed as it *should* be. (c) No
 lawyer by themselves has standing to file suit; behind every lawsuit
 is the citizen or corporation who hired them. (d) At least we're
 governed by the rule of law, not by random mobs and thuggery; for
 that, you might have to thank some people with legal knowledge, and
 some of them are even lawyers!
 Cheers,
 Ihab
 DO NOT ARCHIVE
 Ihab A.B. Awad, Palo Alto, CA
		xl(at)prosody.org Guest
				 Posted: Tue Apr 29, 2008 11:01 pm    Post subject: Zenith Builders Analysis Group |
				I thought the report about the Piper breakup was very good.
 They did a dynamic analysis using a model that supported the
 hypothesis that abrupt control movements, first in one direction then
 the other lead to the wing failure. How about developing a dynamic
 model that could be used to evaluate a number of failure scenarios?
 I too tried to get an Aeronautical Engineering prof interested in
 the analysis - no bite.
 I'd like to know what happens when a flap is extended and the limit
 switch allows the flap arm to leave the motor. I thought that I had
 the flap controls adjusted well. But, on one preflight, the flap
 arm departed and the flap fell unattached. That would leave the flap
 flapping. I normally don't use flaps. But, when I do, I don't extend
 them fully - I got bit in a gusty crosswind once.
 Joe E (at) BFI
 CH601XL, 507 hours
 Jabiru 3300, 64x51 Sensenich wood prop
 On Sat, 26 Apr 2008, Terry Phillips wrote:
  	  | Quote: | 	 		   At 02:24 PM 4/25/2008 -0500, John Bolding wrote:
 > Jeff,
  ......snip  ........snip
  Rev. 0
  April 26, 2008
  CH601XL:
    *  To attempt to determine whether the structure, as designed, has
    * Assuming that the analysis shows that the structure, as designed
    * Evaluate the susceptibility of the flaps and ailerons to flutter. If the
    * Consider the effect of design options on the ability of the wing to meet
  design standards:
        * Hinged vs. skin flex hinge aileron attachment.
        * Aileron trim tab option.
        * Wing locker option.
        * Landing light option.
        * Thirty gallon vs. 24 gallon fuel tanks.
    * Consider, to the extent possible given time and budget constraints, the
        * Wrong size or kind of rivets used at high stress location.
        * Missing, loose, or wrong sized bolts.
        * Mis-placed or wrong sized openings, e.g., the hole for the aileron
        * Two or three piece nose skin
		japhillipsga(at)aol.com Guest
				 Posted: Wed Apr 30, 2008 9:34 am    Post subject: Zenith Builders Analysis Group |
				Andy, lawyers are not lazy! Bill of Georgia
		Andrewlieser
				 Posted: Wed Apr 30, 2008 10:56 am    Post subject: Re: Zenith Builders Analysis Group |
				Has anyone spoke to the Hientz's about this potential independent analysis?  If so as an alternative route for disseminating the results of such an analysis would it be best to provide all of the information and results to Zenith as well.  In doing this you could still provide a copy of the results to all parties that paid for the analysis and allow others to have the information disseminated to them through Zenith therefor disposing of any potential liability of the analysis group.  Just a thought.  I do agree with the comment about the younger generation getting excited about flying in general.  Being 27 it is very transparent to me and sometimes I feel like the last of a dying breed....
  _________________ Andrew Lieser
S/N 6-7045
http://websites.expercraft.com/andrewlieser |
		MHerder
  Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
				 Posted: Wed Apr 30, 2008 11:34 am    Post subject: Re: Zenith Builders Analysis Group |
				Andrew,
 I'm 26 so you're not the very last of the dying breed!  I thought I was one of the youngest builders in the group... That is till I heard about Sabrina...  She puts us all to shame!  I am truly inspired by her story though and look forward to seeing what she will do for aviation in the future.  Perhaps another Burt Rutan!  I am definitely the youngest at my local EAA chapter during our monthly meetings by at least 25 yrs or so.
 Mike Herder
 Zodiac XL Builder
 N318MH
 6-7019
 HT and Rudder Complete, Fuselage is getting ready to get front skins.  I guess I'm about 35-40% there, not bad since I picked up the kit in December 07.
  _________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
		Terry Phillips
				 Posted: Wed Apr 30, 2008 8:43 pm    Post subject: Zenith Builders Analysis Group |
				Good point, Andrew.
 Sounds like a good idea to me. If we are lucky enough to find an engineer
 to do the analysis, and, if we can raise the necessary funds, I think
 Zenith should get a copy of the report.
 And, responding to a earlier post (I think by Craig Payne) it would be
 wonderful to have Zenith support the analysis with data and/or design
 information. I'm not sure how to make that happen. Suggestions, anyone?
 Terry
 At 11:56 AM 4/30/2008 -0700, you wrote:
  	  | Quote: | 	 		  Has anyone spoke to the Hientz's about this potential independent
 Andrew Lieser
 Terry Phillips
 ttp44~at~rkymtn.net
 Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
		numskull99(at)netzero.net Guest
				 Posted: Thu May 01, 2008 2:37 am    Post subject: Zenith Builders Analysis Group |
				I think there is allot more younger people than you may think.  Im 27, and proud to be able to build a 601XL at this age.
 Derek Lewis
 Do not Archive;
 -- "MHerder" <michaelherder(at)beckgroup.com> wrote:
 Andrew,
 Mike Herder
 Zodiac XL Builder
 N318MH
 6-7019
 One Rivet at a Time!
 http://forums.matronics.com/viewtopic.php?p=180348#180348
 _____________________________________________________________
 Put your loved ones in good hands with quality senior assisted living. Click now!
 http://thirdpartyoffers.netzero.net/TGL2211/fc/Ioyw6ijmaeYKsW11c6KlYyFIorMy3anmRZUygvm50UUiXD7OxfgYQ6/?count=1234567890
		Andrewlieser
				 Posted: Thu May 01, 2008 10:03 am    Post subject: Re: Zenith Builders Analysis Group |
				I did not know here were other younger builders on the site!  It's nice to here that!  Just curious were you guys brought up around aviation or were you exposed later on in life???  Just curios!
S/N 6-7045
