wild1ranch(at)wild1ranch. Guest
Posted: Wed Apr 30, 2008 6:26 am Post subject: Looking for Frank Justice manual section |
Im looking for the section "remove from the jig" all the links I find
seem to be broken.
thanks for your help
Bill
Slow build RV6
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
BSchroeder(at)rideuta.com Guest
Posted: Wed Apr 30, 2008 8:07 am Post subject: Looking for Frank Justice manual section |
The printed text?
s.hamer(at)verizon.net Guest
Posted: Wed Apr 30, 2008 8:14 am Post subject: Looking for Frank Justice manual section |
Bill,
It's a very short section. Here's what it says:
Removing the Fuselage from the Jig
Decide how you are going to support the fuselage once you take it out of the
jig. One really handy way is to make bolt-on front legs. Make a couple of
wood strips about 7 1/2" wide and 24" long, then drill them to bolt where
the main spar goes but extending out about 8" outside the skin. Nail 29"
legs to these and you will have your main longeron 45" off the floor when
you turn the fuselage over. Make a skinny sawhorse for the rear. If you
made the imitation wing for mounting -6A gear legs you can cut them down for
this. These legs make it extremely unlikely that you knock the fuselage
over accidentally.
Remove all the clamps and bolts holding the fuselage in, lift it off, and
set it upright.
End
The next section is "Assorted Small Steps".
I hope this helps.
Steve Hamer
RV-6 flying
Apple Valley, Ca
Posted: Thu May 01, 2008 10:50 am Post subject: Looking for Frank Justice manual section |
Thanks Steve,
Sounds like I'm not missing much!
Thanks all for your responses.
Bill
Bill,
the
of
for
over accidentally.
set it upright.
End
I hope this helps.
Steve Hamer
RV-6 flying
Apple Valley, Ca
