		daveleikam(at)wi.rr.com Guest
				 Posted: Mon Feb 27, 2006 3:29 pm    Post subject: Tough to set rudder rivet |
				Probably an old question from a new -10 builder.  How do  you squeeze or set the rivet on the lower right side of the rudder (You know the  one).  I am considering using a blind rivet on both sides.   Anyone?  Thanks!
  Dave Leikam
  #40496
				 Posted: Mon Feb 27, 2006 3:48 pm    Post subject: Tough to set rudder rivet |
				Left a red piece of tape over the hole waiting for someone to make a good
 sugggestion before I use a blind rivet also.
 I even back tracked thnking that these could have been riveted out of
 sequence but that wouldn't have worked either.
 Waiting!
 JG. 409
  	  | Quote: | 	 		  From: "Dave Leikam" <daveleikam(at)wi.rr.com>
 CC: <daveleikam(at)wi.rr.com>
 Subject: Tough to set rudder rivet
 Date: Mon, 27 Feb 2006 17:27:36 -0600
 Dave Leikam
 #40496
		seipel(at)seznam.cz Guest
				 Posted: Mon Feb 27, 2006 4:04 pm    Post subject: Tough to set rudder rivet |
				I used a MK319BS.
 PJ
 #40032
 Dave Leikam wrote:
  	  | Quote: | 	 		   Probably an old question from a new -10 builder.  How do you squeeze
  Thanks!
  Dave Leikam
  #40496
		jeff(at)westcottpress.com Guest
				 Posted: Mon Feb 27, 2006 4:09 pm    Post subject: Tough to set rudder rivet |
				Hi Dave,
 There are a few approaches that work.  I took some meat out of the center of a bucking bar, leaving about a 3/16" thick surface on either side that I could slide in between the rib flanges... allowing me to buck the rivet (my tech counselor was quite impressed).  I'd take a picture of it to show you but it's on loan to another builder.
 Avery also sells a yoke with a tapered head that will work... but you're looking at $85.00.
 Jeff Carpenter
 40304
 Wings/Forward Leading Edge
 On Feb 27, 2006, at 3:27 PM, Dave Leikam wrote:
  	  | Quote: | 	 		  Probably an old question from a new -10 builder.  How do you squeeze or set the rivet on the lower right side of the rudder (You know the one).  I am considering using a blind rivet on both sides.  Anyone?  Thanks!
 Dave Leikam
 #40496
		Eric_Kallio
  Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
				 Posted: Mon Feb 27, 2006 5:17 pm    Post subject: Re: Tough to set rudder rivet |
				Dave, I was shown how to use a thin nose yoke that was ground down a fraction of an inch. Using this I was able to squeeze the first rivet without a problem. For the other side it took two of us, one to squeeze the rivet and one to flex the spar just a hair. I was able to get the very edge of the yoke in the gap and used the edge of a wide flush set on the manufactured head. I would squeeze the rivet a hair and as it set I was able to get the yoke farther in the gap, until I was able to fully set the rivet. Sounds more painful than it was. The hard part will be finding the yoke.
 Eric Kallio
 40518
 Tailcone
		wcurtis(at)core.com Guest
				 Posted: Tue Feb 28, 2006 12:44 pm    Post subject: Tough to set rudder rivet |
				That bar, without some modification, will not fit that space.
 Jeff Carpenter
 40304
 On Feb 28, 2006, at 11:15 AM, William wrote:
  	  | Quote: | 	 		   >How do you squeeze or set the rivet on the lower right side of
  >Dave Leikam
  >#40496
  Used the 15000 bucking bar at the below link:
  http://www.yardstore.com/index.cfm?
  action=ViewDetails&ItemID=380&Category=74
  The small pointed end is great for tight spaces.
  William Curtis
  http://wcurtis.nerv10.com/
